No, I was just making sure it's not something that was fixed in the patch. Doug will be the one to talk to about this, when he gets back. He does a good job of fixing the rivers up. Actually, I'm surprised that it's not. I haven't been able to check out that run recenty, so I'm not sure what It looks like for me.
If you want to get past those areas, and can't drive through them with the boat, slew past the spot, then continue from there. Make a mental note to tell Doug about the spots when he gets back. Could you get the coordinates for the spots so they can be easily found? Place your boat/plane on the spot, then go to the map (alt, w, m) and copy the Lat/Lon from there. That would be great, thanks.
-------- We need to get back on topic. "Screenshots" of boats. -----------------------------
Actually, there is a "sticky" thread called "Anomalies on the water", you could continue the topic in there, by posting the screenshots and coordinates there. Sorry I pulled us off course a little there. Now, back to the boat screen shots. Thanks.
