Home (FSX/P3D)
Home (MSFS2020)
Scenery
Navigation
Enhancements
Activities
Welcome,
Guest
. Please
login
or
register
April 25, 2024, 04:56:26 PM
Home
Help
Login
Register
Misty Moorings Forums
Help and Troubleshooting
tongass Narrows Float Plane Scenery Pack
« previous
next »
Print
Pages: [
1
Author
Topic: tongass Narrows Float Plane Scenery Pack (Read 1699 times)
shermank
Member
on:
October 13, 2021, 08:47:26 AM »
Hi all,
I discovered this today, but the readme mentions installation for FSX. I fly P3D V5.1. Is this compatible, or should I just delete the DL. Thanks.
Sherm
Logged
Misty Moorings Team
Hero Member
Misty Flying Club VA, Sim Troubleshooting & Help
Re: tongass Narrows Float Plane Scenery Pack
Reply #1 on:
October 13, 2021, 10:57:08 AM »
Yep works for P3Dv5x. With Tongass Fjords X (ai models must be updated) and Orbx PAKT.
Tongass X:
The ai aircraft models in Tongass X have be updated for use in P3Dv4 and 5x. (If you used the Tongass "add-on" they have already updated for use in P3Dv4/5). If you used the older version of Tongass X then you have to update a few of the AI aircraft models in that package
REFER To: AI Aircraft for Tongass x: LINKS:
https://return.mistymoorings.com/s_getting_started/index.php#5
or
https://return.mistymoorings.com/s_getting_started/index.php#9
Tongass Narrow Floats:
If you used the RTMM Add-on to add all of the RTMM scenery, Tongass Narrows Floats is already set up.
If you are using single pieces and are setting up your own RTMM scenery then you have to add it yourself. (With the Tongass X AI aircraft Model updated) (but it, itself, is compatible with P3Dv5).
Last Edit: October 13, 2021, 10:59:57 AM by nbrich1
Logged
shermank
Member
Reply #2 on:
October 14, 2021, 07:41:19 AM »
Thanks Norm....
Sherm
Logged
Print
Pages: [
1
« previous
next »
