Author Topic: FS2020 CTD while loading  (Read 1796 times)
John
« on: June 21, 2021, 06:02:53 PM »
Everything has been working great since update V until today.  I can't get FS2020 to load.  Tried 3 times with PC reboot in between.  Here is last error msg.
- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
  <Provider Name="Application Error" />
  <EventID Qualifiers="0">1000</EventID>
  <Version>0</Version>
  <Level>2</Level>
  <Task>100</Task>
  <Opcode>0</Opcode>
  <Keywords>0x80000000000000</Keywords>
  <TimeCreated SystemTime="2021-06-21T20:49:36.5743983Z" />
  <EventRecordID>2047</EventRecordID>
  <Correlation />
  <Execution ProcessID="0" ThreadID="0" />
  <Channel>Application</Channel>
  <Computer>Johnsputer</Computer>
  <Security />
  </System>
- <EventData>
  <Data>FlightSimulator.exe</Data>
  <Data>0.0.0.0</Data>
  <Data>60c0b1e3</Data>
  <Data>unknown</Data>
  <Data>00000000</Data>
  <Data>c000001d</Data>
  <Data>000001b767ee2995</Data>
  <Data>2ff0</Data>
  <Data>01d766de4c114f47</Data>
  <Data>C:\Program Files\WindowsApps\Microsoft.FlightSimulator_1.17.3.0_x64__8wekyb3d8bbwe\FlightSimulator.exe</Data>
  <Data>34678f69-f57e-4550-8854-484a7224437b</Data>
  <Data>Microsoft.FlightSimulator_1.17.3.0_x64__8wekyb3d8bbwe</Data>
  <Data>App</Data>
  </EventData>
  </Event>
Could use lots of advice.  Thanks
John MFC0016
Re: FS2020 CTD while loading
« Reply #1 on: June 21, 2021, 09:51:57 PM »
Well here goes nothing John:
Steps:
Computer shutdown.
Start PC.
Run Windows Update.
Update GPU driver.
MSFS:
Make sure nothing is in your community folder. (Empty it).
> Start SIM. (without FSUIPC7x): So a clean boot to the sim.
If still CTD:
Delete Hidden Folder:
C:\Users\your name\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\SceneryIndexes  (Folder (and required files) will rebuild on restart)
Delete file:  Content.xml
C:\Users\norm_\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\Content.xml (File will rebuild on restart)
Delete file:  FlightSimulator.CFG
C:\Users\norm_\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\FlightSimulator.CFG     (File will rebuild on restart but will have to reset some of your display  options (if not default)
Delete file: ROLLINGCACHE.CCC
C:\Users\norm_\AppData\Local\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\LocalCache\ROLLINGCACHE.CCC
Try SIM: > Start SIM. (without FSUIPC7x): So a clean boot to the sim.
If still a CTD, then type APPS in the windows 10 search bar > RUN Apps & Features  > Scroll down to Microsoft Flight Simulator > Advanced Options > Repair (Click Repair to execute)
When done, shutdown PC  > Start PC > -> Start SIM. (without FSUIPC7x): So a clean boot to the sim.
If still a CTD, reinstall from the store.
John
« Reply #2 on: June 22, 2021, 03:42:46 PM »
Hi Norm, I worked with Zoolander yesterday.  Moved community folder and reinstalled sim.  Thought we had it but I was browsing around in the sim and when I clicked on aircraft, CTD.  I'll try your suggestions.  Thanks for all the input.  Will report back.
John
John
« Reply #3 on: June 23, 2021, 07:15:37 PM »
Norm, I did everything you listed and something worked  ;D  My sim is loading and running again  8)  Thanks for the help.
John
« Reply #4 on: June 23, 2021, 07:53:05 PM »
Those step by steps usually fixes things up.  Just saw your MSFS pirep so I know it's working! Glad you're back in the air John.
Best Regards Sir Dean
