Flight from S20 to OG20 this morning went well, but winds required landing on runway 25, which made for a long taxi in, taxiing back on 07/25 to the intersection of RWY 16/34, then to the hangars at the south end of the field, which may have confused CB. End result was that I couldn't file a PIREP for the flight.
Here's my Flight Log:
[06:08] ----- Flight Opened -----
[06:08] Cigar Box - 1.1.4.0
[06:08] FS:
[06:08] FSUIPC: v7.008
[06:08] Flight Number: MFCYODA
[06:08] FS Aircraft: XCub N25391
[06:08] FS Model: TT:ATCCOM.AC_MODEL_CC19
[06:08] FS Type: TT:ATCCOM.ATC_NAME_CUBC
[06:08] Departure: S20
[06:08] Arrival: OG20
[06:08] Flight Level: 3000
[06:08] Flight Type: H
[06:08] Passengers: 0
[06:08] FOB: 288 lbs
[06:08] Gate: n/a
[06:08] NOTE: Parking Brake Ignored
[06:08] Crash Detection Aircraft: Disabled
[06:08] Engines: 1 Piston
[06:08] NOTE: Boarding has started
[06:08] Parking Brake: Engaged
[06:08] Main Door Closed
[06:08] COM1: 118.30
[06:08] COM2: 124.85
[06:08] Transponder: 1200
[06:08] NAV1: 110.50
[06:08] NAV2: 110.50
[06:08] ADF1: 890.0
[06:08] ADF2: 890.0
[06:08] Navigation Mode: NAV
[06:08] Flaps: Position 1
[06:08] Flaps: Position 2
[06:08] Flaps: Position 3
[06:08] Flaps: Position 0
[06:09] Parking Brake: Released
[06:09] Parking Brake: Engaged
[06:09] Light Data: Strobe lights ON
[06:09] Light Data: Instrument lights ON
[06:09] Engine 1: Started
[06:10] Navigation Mode: GPS
[06:11] NAV1: 112.30
[06:12] Light Data: Navigation ON
[06:12] Light Data: Landing lights ON
[06:12] Light Data: Taxi lights ON
[06:13] Parking Brake: Released
[06:13] NOTE: Taxi started
[06:15] Parking Brake: Engaged
[06:15] Parking Brake: Released
[06:17] NOTE: ----- TAKE OFF -----
[06:17] GS: 62 knots
[06:17] TAS: 66 knots
[06:17] IAS: 55 knots
[06:17] VS: -10 fpm
[06:17] FOB: 287 lbs
[06:17] Heading: 272°
[06:17] Pitch: 3°
[06:17] Bank: 0°
[06:17] Aircraft Weight: 1807.31 lbs
[06:17] Nearest Airport: 35S
[06:17] Distance: 16.20 miles
[06:17] Runway:
[06:17] Ground Surface: Concrete
[06:17] Ground Condition: Normal
[06:17] NOTE: Weather Report
[06:17] Wind Heading: 225°
[06:17] Wind Speed: 4 knots
[06:17] OAT: 22° C
[06:17] TAT: 22° C
[06:17] Precipitation: None
[06:17] Dew Point: 0° C
[06:17] Visibility: 27 miles
[06:17] METAR:
[06:17] NOTE: Climb started
[06:17] View Mode: Virtual Cockpit
[06:18] NOTE: TOC reached
[06:18] NOTE: Cruise started
[06:18] GS: 106 knots
[06:18] TAS: 111 knots
[06:18] IAS: 102 knots
[06:18] VS: 196 fpm
[06:18] FOB: 285 lbs
[06:18] Heading: 154°
[06:18] Pitch: 1°
[06:18] Bank: 13°
[06:18] Aircraft Weight: 1805.72 lbs
[06:18] NOTE: TOD reached
[06:18] NOTE: Descent started
[06:18] GS: 128 knots
[06:18] TAS: 128 knots
[06:18] IAS: 122 knots
[06:18] VS: -406 fpm
[06:18] Pitch: 2°
[06:18] Bank: 0°
[06:18] Aircraft Weight: 1805.11 lbs
[06:18] NOTE: On approach
[06:27] COM1: 123.00
[06:35] Light Data: Landing lights OFF
[06:35] AGL: 2543 ft
[06:35] AMSL: 2618 ft
[06:35] Light Data: Recognition lights ON
[07:04] Flaps: Position 1
[07:04] GS: 73 knots
[07:04] TAS: 78 knots
[07:04] IAS: 70 knots
[07:04] VS: -315 fpm
[07:05] Flaps: Position 2
[07:05] GS: 64 knots
[07:05] TAS: 63 knots
[07:05] IAS: 54 knots
[07:05] VS: -385 fpm
[07:05] Flaps: Position 3
[07:05] GS: 62 knots
[07:05] TAS: 61 knots
[07:05] IAS: 52 knots
[07:05] VS: -718 fpm
[07:06] Flaps: Position 1
[07:06] GS: 48 knots
[07:06] TAS: 49 knots
[07:06] IAS: 39 knots
[07:06] VS: -464 fpm
[07:06] Flaps: Position 0
[07:06] GS: 66 knots
[07:06] TAS: 67 knots
[07:06] IAS: 59 knots
[07:06] VS: 152 fpm
[07:07] Flaps: Position 1
[07:07] GS: 79 knots
[07:07] TAS: 84 knots
[07:07] IAS: 76 knots
[07:07] VS: 657 fpm
[07:08] Flaps: Position 2
[07:08] GS: 68 knots
[07:08] TAS: 67 knots
[07:08] IAS: 58 knots
[07:08] VS: -98 fpm
[07:09] Flaps: Position 3
[07:09] GS: 60 knots
[07:09] TAS: 63 knots
[07:09] IAS: 54 knots
[07:09] VS: -719 fpm
[07:10] Stall: Encountered
[07:10] GS: 42 knots
[07:10] TAS: 43 knots
[07:10] IAS: 33 knots
[07:10] VS: -244 fpm
[07:10] NOTE: ----- LANDED -----
[07:10] Landing Rate: -254.52 fpm
[07:10] VS: -250 fpm
[07:10] FOB: 233 lbs
[07:10] Heading: 252°
[07:10] Pitch: 7°
[07:10] Bank: 0°
[07:10] Aircraft Weight: 1753.41 lbs
[07:10] Nearest Airport: 5S9
[07:10] Distance: 9.94 miles
[07:10] Runway: 25 - OG20
[07:10] Ground Surface: Short Grass
[07:10] Ground Condition: Normal
[07:10] NOTE: Weather Report
[07:10] Wind Heading: 261°
[07:10] Wind Speed: 1 knots
[07:10] OAT: 20° C
[07:10] TAT: 20° C
[07:10] Precipitation: None
[07:10] Dew Point: 0° C
[07:10] Visibility: 20 miles
[07:10] METAR:
[07:10] View Mode: Virtual Cockpit
[07:10] NOTE: Taxi started
[07:10] Flaps: Position 1
[07:10] Flaps: Position 0
[07:12] Light Data: Landing lights ON
[07:12] Light Data: Recognition lights OFF
[07:12] Light Data: Navigation OFF
[07:13] NOTE: Arrived
[07:13] Parking Brake: Engaged
[07:13] Light Data: Landing lights OFF
[07:13] Light Data: Taxi lights OFF
[07:14] Engine 1: Stopped
[07:14] View Mode: Spot Plane
[07:14] Parking Brake: Released
[07:14] Light Data: Strobe lights OFF
[07:14] Light Data: Instrument lights OFF
[07:14] Navigation Mode: NAV
[07:14] COM1: 118.30
[07:14] Transponder: 0000
[07:14] NAV1: 110.50
[07:16] NOTE: ----- TAKE OFF -----
[07:16] GS: 0 knots
[07:16] TAS: 0 knots
[07:16] IAS: 0 knots
[07:16] VS: 0 fpm
[07:16] FOB: 0 lbs
[07:16] Heading: 0°
[07:16] Pitch: 0°
[07:16] Bank: 0°
[07:16] Aircraft Weight: 0.00 lbs
[07:16] Nearest Airport: TWNL
[07:16] Distance: 3818.68 miles
[07:16] Runway:
[07:16] Ground Surface: Concrete
[07:16] Ground Condition: Normal
[07:16] NOTE: Weather Report
[07:16] Wind Heading: 0°
[07:16] Wind Speed: 0 knots
[07:16] OAT: 0° C
[07:16] TAT: 0° C
[07:16] Precipitation: None
[07:16] Dew Point: 0° C
[07:16] Visibility: 0 miles
[07:16] METAR:
[07:16] Landing Gear: Retracted
