Author Topic: Any Idea how to fix this?  (Read 2650 times)
Brian_Gladden
« on: May 30, 2021, 12:44:15 PM »
So... I'm running P3D V3. I have Orbix Global vector and landclass. Pacific Fiords and Southern AK. I just installed Tongass X (the non installer version for P3d I got here. I used to own a copy of Tongass when I ran FSX) and I have Tongass' scenery entries above Orbix global but below my scenery entried for the Orbix regions.
Re: Any Idea how to fix this?
« Reply #1 on: May 30, 2021, 01:46:20 PM »
Hi Brian,
     Welcome to the RTMM forum and community.  8)
Maybe the info in this thread will be of some help?   :-\
https://forum.mistymoorings.com/index.php?topic=4375.0
« Reply #2 on: May 30, 2021, 03:27:40 PM »
You have to manually put in the 40 Tongass terrain entries into the P3D terrain.cfg file for use in any version P3D version.
« Last Edit: May 31, 2021, 10:27:02 AM by nbrich1 »
Brian_Gladden
« Reply #3 on: May 31, 2021, 08:49:23 AM »
Okay.... Still as clear as mud...
Is there a text file I can copy and paste to make this work somewhere?
 I didn't use the installer version available here so I have no cfg entries for Tongass. Just my Orbx stuff.
« Reply #4 on: May 31, 2021, 10:26:30 AM »
I have attached the Terrain.cfg entries and how to in the zip file attached to this post.
(The full and read and entries are in the Tongass Add-on (Refer to the Docs-Install folder)
« Reply #5 on: May 31, 2021, 11:16:49 AM »
  Yes, editing the "terrain.cfg" file to add the 40 TFX entries is a mandatory step.  Also, correct placement of the higher and lower folders in the scenery library.  After that, setting the insertion point in Orbx Central to keep things in place are necessary for it to show correctly.   ;)
Brian_Gladden
« Reply #6 on: June 01, 2021, 06:47:37 PM »
Thanks!
Brian_Gladden
« Reply #7 on: June 01, 2021, 08:47:27 PM »
Still no joy...
No ocean, all 40 entries in. Restarts of the sim between edits. Only thing that might be an issue is I have Tongass in my addon scenery folder instead of FS Addon.
