Author Topic: Trouble Downloading the RTMM_Master file  (Read 3163 times)
jstanbro
« on: December 03, 2020, 01:52:32 PM »
Hi,
I am reinstalling FSX-SE and want to try the RTMM Master file this time.
I have downloaded the file four times.  Each time Google drive hassles me a little bit about hhow it can't scan the file, but it seems to download just fine each time.
However, when I try to unzip the file I run into trouble, whether I use WinZip or Windows.  Each time the computer chokes on the file in the same place and I get the message in the attached screenshot.
I know that lots of other people have downloaded and unzipped this file just fine, but I don't know what I am doing wrong.  Any ideas?
"The hardest thing about flying is the ground." - Charles Kingford-Smith
Re: Trouble Downloading the RTMM_Master file
« Reply #1 on: December 03, 2020, 02:49:10 PM »
One possibility....
Depending on your system structure, the unzip may create a "path too long" situation. It may only be a few letters.   Copy the zip file to the G: root drive and try to unzip it there instead of into a folder that is already created on the G: root drive that adds several more characters to the path.
Just a thought....
« Reply #2 on: December 03, 2020, 05:04:17 PM »
Strange...
Drive letter G suggests you have a lot of drives installed. Which drive is G?  A regular disk? Or rather a USB stick? An external drive formatted with an outdated filesystem? Or even a DVD?
Did extracting to G: ever work? If yes, Rods tip probably is a good one.
« Reply #3 on: December 03, 2020, 05:06:48 PM »
Wasn't there an option to maintain drive and directory? Do you even have a G drive?
« Reply #4 on: December 03, 2020, 06:14:49 PM »
Hi Karl,
I have C:, D:, E:, F:,  and G: internal drives for a total of 7 TB.  All are SSDs excpet E: which is a conventional WD Green drive.  I also have an external 4 TB My Book drive for backups.
« Reply #5 on: December 04, 2020, 01:28:20 AM »
I don't have a "G" drive.  But I do have -
A:  Floppy Disk Drive
C:  1T SSD
D: DVD RW Drive
E: IPOD
F: thumb drive
M: 1T M2 Drive
N: 2T M2 Drive
P: 1T SSD
Q: 2T SSD
R: 1T SSD
S: 4T HDD
U: 500GB SSD
 :o ???
Wow, yes!  That path statement is quite large indeed.  I agree with Rod.  ;)
« Last Edit: December 04, 2020, 01:01:19 PM by jeff3163 »
« Reply #6 on: December 04, 2020, 07:23:49 AM »
Knew the long path of a couple folders/files might cause a problem depending on where extracted. Will truncate in the next version.
Man, you guys also have lots of drives: with some speedy drives as well as lots of capacity/storage!. Nice!
« Last Edit: December 04, 2020, 08:43:49 PM by nbrich1 »
jstanbro
« Reply #7 on: December 04, 2020, 06:30:05 PM »
Thanks for the help, guys!  I finally got it.  I followed Rob's suggestion and ended up shortening the name of the file to "R" in the C: root directory (C:/R) and WinZip unzipped it.
Yes, I do have a G: drive (don't know why "G"...). I use it mostly for downloads and backups.
Thanks again for your help!
Jerry
« Reply #8 on: December 05, 2020, 07:32:33 AM »
Hi Jerry,
Glad you got the files unzipped.  Enjoy!
« Reply #9 on: December 05, 2020, 09:15:36 AM »
Rod always has a helpul answer!
