Welcome Back Jmac:
As per - extract the zip and place all of the folders where you need them:
Addon Scenery to where you want it (Make note of the path to this folder)
Effects to Effects (Select Correct Version for FSX-SE)
Gauges to Gauges
Scenery to the sims main Scenery folder
Simobjects to Simobjects
Sound to Sound
Now: to the template scenery.cfg.txt file itself and all the RTMM entries. This will be direct input into the scenery.cfg once the correct path setup- then the entries from this file are pasted at the bottom of your entries in your scenery.cfg (after you backup your copy). Might need a tweak depending on your addon scenery but this whole process is to save manually setting up 241+ of these RTMM scenery entries in your sim scenery library. Now you can do that, this is just a must faster way to do the same thing.
where you only have to open this scenery.cfg template file with notepad and substitute or replace the " Local=x:\path to Addon Scenery " with your correct path using notepad's Edit > Replace Command.
IE: So if your add-on scenery was placed on drive D:\Fightsim\addon scenery\ ....
It would be a matter of editing the template file: using the notepad's Edit > "replace" function:
So Open the template file with notepad - EDIT > Replace
Find what: Local=x:\path to Addon Scenery \
Replace with: Local=D:\Fightsim\addon scenery\
and the rest of the line will match up with the specific scenery entries and folders.
IE:
[Area.449]
Title=RTMM-01-RTMM Object Libraries 1-2-3-4 <-----(ORBX Top Insertion Point)-----<
Local=x:\path to Addon Scenery \RTMM\01-RTMM Object Libraries 1-2-3-4
Layer=449
Active=TRUE
Required=FALSE
So after one "Replace" replacement then the path (or local=) of that entry
Local= line would read:
[Area.449]
Local=D:\Fightsim\addon scenery\RTMM\01-RTMM Object Libraries 1-2-3-4
Layer=449
Active=TRUE
Required=FALSE
and the scenery entry is complete.
If you use the "Replace ALL" function in that notepad replace function, then the paths of all the entries in that rtmm template file are done.
IE:
[Area.674]
Title=RTMM-Twelve Mile Rafting Station
Local=x:\path to Addon Scenery \RTMM\05-RTMM Addon Scenery\Twelve Mile Rafting Station
Layer=674
Active=TRUE
Required=FALSE
becomes
[Area.674]
Local=D:\Fightsim\addon scenery\RTMM\05-RTMM Addon Scenery\Twelve Mile Rafting Station
Layer=674
Active=TRUE
Required=FALSE
Then select all of the entries from the template txt file (copy) and paste at the bottom of your scenery.cfg (after you back up your original scenery.cfg). (Just saves much time in manually entering all the entries in your sim library but if you want you could manually enter all of these entries in your scenery.cfg.. (but start with the libraries and add in alpha order and each will layer on top of the previous with RTMM-Yukon Crossing being the last entered and it ends up on top of the scenery library.
Now if you want, can do it for you. If you send me your current scenery.cfg file (zip it up) and convey what drive/location your addon scenery folder is located check and update your scenery.cfg as required and send it back to you. (
norm_richards@hotmail.com)
