[UPDATE] MSFS2020 Release Notes (1.10.7.0) Update #5 Now Available!
Some packages in your community folder may not have been updated and, as a result, may have an unexpected impact on the title’s performance and behavior. Please move your community package(s) to another folder before relaunching the title if you suffer from stability issues or long loading times.
PLANES
Improved sensitivity and twitchiness of control surfaces for the Daher TBM 930, Cessna 152, Cessna 152 Aerobat, Cessna 172 classic and Cessna 172 G1000
Improved autopilot behavior for pitch management, altitude capture and stability for Cessna 208 B Grand Caravan EX, Cessna Citation Longitude, Boeing 747-8 Intercontinental and Daher TBM 930
Fixed Zlin Shock Ultra caution amber light which was always on
Fixed Cirrus SR22 windshield deicing not working
Fixed Cessna 152 flood light always ON during tutorials
Fixed aircraft avionics screens going blank in certain conditions
Fixed Boeing 787-10 Dreamliner APU fault light behavior
Unlocking longitudinal position of elevator to allow for “Canard” airplanes
UI
Press any key to start screen is now automatically skipped at launch
Option added to the Misc menu to switch between Metric and US standard units
Performances has been improved in plane selection menu and marketplace
The TrackIR can be enabled/disabled in the camera panel during flight
Cockpit tooltips can now be deactivated in the Accessibility options menu
WEATHER
Metar data refresh issue has been fixed
INSTALLATION MANAGER
Solved several installation issues that were affecting edge cases
We now display the download speed and amount of packages that are being downloaded
INPUT
Support for Thrustmaster TCA Quadrant Airbus Edition
Ability to move the origin of the sensitivity curve and change the sensitivity value on both side of the origin
Fix input values when using deadzones
ACTIVITY
All Landing challenge scores should now be properly tracked in the leaderboards
MARKETPLACE
Quality of life updates for the marketplace
WORLD
Motion blur has been added
New temporal anti-aliasing (TAA) has been implemented
The temporal upsampling has been fixed (when TAA is active with the render scale below 100%)
Night lighting has been improved
Water night reflections have been added
Huge hole in Brazil has been fixed
KNOWN ISSUES
VNAV can overshoot the climb speed. Disconnecting the AP after take off and re engaging it will limit the overshoot impact
The Cessna Citation Longitude can be slightly below the glide slope as you get close to the airport
Once activated, the Switch to Mach units knob won’t return to knots on the Airbus A320neo
Live weather fails to save properly after restarting the game
UI fails to refresh after you Buy & Download any item, letting the download button appear
