Author Topic: MilViz BWEP DHC-2 Install questions  (Read 2206 times)
ChuckOman
« on: August 25, 2020, 02:13:30 PM »
Attempting to install Klaus Troppner's handsome BWEP repaint in to MilViz DHC-2 Beaver (v171229 + MV_WX_Radarv1.190514 patch).  I understand how the aircraft.cfg edits go.  But wasn't confident I understood which folders go where:
-The zip download includes a textureN217MM folder, three thumbnail folders and a "cockpit" folder.  Is it correct that all five folders should be copied into the DHC-2 Beaver MIlviz folder (the base), and that these same five folders should also should be copied into each of the three other version folders (floats, tundra, skis)?
- This repaint includes panel mods, dated 2017.  Are they optional ?  Will they work with the latest MilViz release, that has panel options for the F1 GTN650/750, Mindstar and RXP GPSes ? If yes, where exactly should the three modified .dds files provided go ?  Instructions don't say.  There are now thirteen panel folders for the various avionics variants, but none contain any .dds files.
Would appreciate any advice.
Many thanks
Chuck O
