Author Topic: MFC Tour 0043 Rockies 3  (Read 1682 times)
tomse
« on: July 03, 2020, 03:06:21 AM »
Leg 3 KDVT Phoenix Deer Valley to KGYR to Phoenix Goodyear
There is a little flightplan confusion depending if you use LittleNavMap (LNM) or PlanG.
Heading for the second waypoint AZ34, LNM leads you to AZ34 Massey Farm (leg distance 117 nm, 291°),
PlanG leads you to AZ34 Harts Field (leg distance 14nm, 260°).
If you use autopilot and LNM as moving map, your plane will fly the way to Harts Field and you are wondering why it does not follow the course in LNM, if you fly manually and follow the course in LNM your are facing a long ride to Massey FArm and back to the Phoenix area.
If you use PlanG, manually or autopilot, you will find your destination easily, all OK.
Thats the result of the the new P3Dv5 db.
