Author Topic: Poll: What Sim do you use?  (Read 19954 times)
kronovan
Re: Poll: What Sim do you use?
« Reply #45 on: August 19, 2020, 12:44:28 PM »
Dieter and Jeff have already raised the question that immediately came to mind when I glanced at the latest poll results - how do 3 members have RTMM for FS2020 when from all I've read it isn't comaptible with FSX/Prepar3D scenery? For that matter, X-Plane should probably be removed from the poll, because it isn't possible to install the RTMM sceneries for it.
I've got to say, that if the RTMM forums become anything like the Steam FSX forum, where every 3rd post is FS2020 related, I"m going to become  grumpy darrn fast . My recommendation is for the the poll creater to remove FS2020 and X-Plane, then add back FS2020 once it's been proven that Tongas X and  RTMM scenery can indeed be installed for it.
« Reply #46 on: August 19, 2020, 01:24:44 PM »
I agree with that recommendation.  No FS2020 or X-Plane.
tomse
« Reply #47 on: August 19, 2020, 02:03:17 PM »
absolutely with you !
« Reply #48 on: August 19, 2020, 08:59:16 PM »
I hear you.  The poll has been edited to only include viable simulators.   ;)
« Reply #49 on: August 20, 2020, 10:42:23 AM »
Thanks, Jeff.
jmsmth
« Reply #50 on: August 20, 2020, 02:25:56 PM »
I switched to v5.  add one to v5 and deduct one from v4.5
« Reply #51 on: August 20, 2020, 08:17:36 PM »
Sorry, I can't change the votes.  I can only add or remove the choices available.  I don't think you can vote twice either, so . . .  :-\
 It's ok.   ;)
« Last Edit: August 20, 2020, 08:25:10 PM by jeff3163 »
gert57
« Reply #52 on: August 21, 2020, 06:58:20 AM »
Hi,
I fly P3D V4 because of the planes I fly most don't work to well in P3D V5.
I won't switch to msfs because same reason AND I cant use RTMM there.
Thirdly I don't want to spend to much €€€ on a hobby.
I consider a good set of controls more important than a new sim, especially if you are bush flying...
Thanks for all the good work,
Gert
kronovan
« Reply #53 on: August 22, 2020, 04:07:54 AM »
Thanks for making that change Jeff. That's helped alleviate some of my grumpiness and I now find myself able to stop gnawing on my shiny new flight yoke's handle.  :P
« Reply #54 on: March 22, 2021, 12:00:53 AM »
     Some time has passed, and I'm curious.  Any RTMM scenery or TFX installed in MSFS2020?  If so, I will add it back to the poll.  This is an "ongoing poll", and there is still time to get your sim counted.   ;)
« Reply #55 on: March 22, 2021, 05:27:53 AM »
Not really an ongoing poll, if anything we need a brand new one.
Now 90% MSFS and 10% P3Dv5. There is now many members here that now use MSFS.
« Reply #56 on: March 22, 2021, 09:03:56 AM »
Wow.  Yes, with thinking like that.  We do need a new poll.  90/10?  Really?  I haven't gone to P3Dv5, and don't plan to.  Where do I fall into your assumption?
« Reply #57 on: March 22, 2021, 12:48:29 PM »
Interesting. I haven‘t switched to MSFS and will not until helicopters are officially supported.
« Reply #58 on: March 22, 2021, 02:34:16 PM »
I was referring to myself Jeff.  I, personally at this time, probably fly in MSFS @ 90% of the time. (But will have to say with 10% in P3D only to be able fly the legs of the MFC tours as the next 13 or so are full of RTMM stuff. Once those are completed will most likely fly even more in MSFS because I have found that its quality and performance are so much better than in any other sim.
Everybody else can fly in whatever sim(s) they choose and for whatever their reasons. It's all good.
« Last Edit: March 22, 2021, 04:38:25 PM by nbrich1 »
John
« Reply #59 on: March 22, 2021, 02:58:54 PM »
I too am hooked on MSFS, big learning curve for me.  Right now probably 50-50 MSFS and FSX-SE  8)
John
MFC0016
