Author Topic: Flight Replicas Super Cub  (Read 5059 times)
xxd09
« on: May 14, 2020, 07:49:00 AM »
Done a wonderful thing and released a free Flight  Replicas Super Cub Experimental for the Flight Sim community-a full v5 version
Flying as I speak
Saw it originally on Avsim boards
xxd09
Re: Flight Replicas Super Cub
« Reply #1 on: May 18, 2020, 07:53:15 AM »
Thx, just downloaded it.
Garry
« Reply #2 on: May 22, 2020, 04:14:25 PM »
May I ask where I can find it, please?
« Reply #3 on: May 24, 2020, 03:18:37 AM »
« Reply #4 on: May 24, 2020, 09:41:41 AM »
Wonderfull plane
Paint by Jan Kee Blom
Garry
« Reply #5 on: May 24, 2020, 07:26:59 PM »
Thanks, Dieter.
Downloading now.
Garry
YoYo
« Reply #6 on: June 03, 2020, 06:33:27 PM »
Ok, 2 cents from my side. Do You like green? ;) Take HULK skin (soon) for FR Super Cub Ultra.
Inspiration for this skin was Super Cub (modded for 4 places) of Kirk Ellis (N1169A). This skin was created for Today's standard - hi-res and some cockpit changes also. Tested and created in P3Dv5. Btw. you need FR Super Cub but Ultra version (FSX, it works well in P3Dv5 also, without any issue). I did this skin for Ultra, not for Extreme version because I needed to have different wing mechanics (in real this plane has similar wings like Ultra, not standard).
The preview:
The repaint is near finish, I must creat zip file only.
« Last Edit: June 03, 2020, 06:51:21 PM by YoYo »
Webmaster of www.yoyosims.pl
YoYo
« Reply #7 on: June 06, 2020, 03:17:07 AM »
Repaint is ready for download on SOH http://www.sim-outhouse.com/sohforums/showthread.php/119935-Super-Cub-Ultra-quot-Hulk-quot-N1169A-zip , soon on FlightSim and Avsim.
« Reply #8 on: June 06, 2020, 04:20:20 AM »
 8) Very nice.  Thank you.  :)
« Reply #9 on: June 06, 2020, 06:57:14 AM »
Nice job yoyo..
Downloading now!.
Definitely needed a Green Super Cub to fit in here at RTMM!.
Thank-you so much sir.
« Reply #10 on: June 07, 2020, 08:30:14 AM »
I try on V5 and don't match this Super Cub Hulk livery .  :'(
i only have PA28_180 ..
« Reply #11 on: June 07, 2020, 08:47:32 AM »
You need this plane -  (Freeware!)
http://www.flight-replicas.com/SuperCubv5.htm
(A gentle upgrade of the original FSX Super Cub Extreme2, to Prepar3Dv5 standards.
This includes:
New wings; new tires, upgraded cockpit parts, new extrnal model panel with functioning instruments and clickable switches, buttons, etc. (so you can start it before you get in, if you like); 4K textures, including spec and alphas, tweaked airfiles, tie-down ropes and windscreen cover for when parked, and the ability to hand prop for starting.
Plus a new Paint kit.   (for the painters out there!)
______________________________________________________________________________________
Every attempt has been made to ensure that prior FSX and P3D paint schemes will work on this model, but have not been tested. To the same degree, this model may work in P3Dv4.5 and FSX, but has not been tested.
History:
The Super Cub is one of aviation's most successful aircraft stories. In close to 40 years of production, over 9,000 were built, and a number of specialty companies continue to produce replicas and further developments to this day.
Introduced in 1949 by Piper Aircraft, it was developed from the Piper PA-11, and traces its lineage back through the J-3 to the Taylor E-2 Cub of the 1930s.
The Super Cub remained in production with Piper through until 1981, when almost 7500 had been built over an uninterrupted 32 year production run. Piper continued building Super Cubs on behalf of Texas based WTA who held the manufacturing and marketing rights from 1981 until 1988. In 1988 Piper resumed marketing responsibility for the Super Cub and continued low rate production. Financial troubles meant that Super Cub production ceased in 1992, before resuming once more the following year. Finally in late 1994 Piper announced that the Super Cub would not form part of its model line for 1995 and that it would cease production after the last of 24 on order for distributor Muncie Aviation were completed. (source: Airliners.net)
Famed as a Bush Plane on wheels, floats and skis, Super Cubs can be found all over the world in a great variety of roles, from a general GA aircraft to banner towing and glider tug.
Today, companies such as CubCrafters, Backcountry, Turbine and Mackey offer kits, parts and fully assembled aircraft for those who want to continue flying this outstanding aircraft design.)
« Reply #12 on: June 07, 2020, 09:36:42 AM »
hi nbrich1
it's the same  ;D i have .
« Reply #13 on: June 07, 2020, 10:41:20 AM »
Yoyo said,
I did this skin for Ultra, not for Extreme version (free add on from Flight Replicas for P3Dv5) because I needed to have different wing mechanics (in real this plane has similar wings like Ultra, not standard).
I believe it is this one: $30?  I don't see any free ones.  :-\
http://www.flight-replicas.com/SuperCubUltrapkg.htm
« Last Edit: June 07, 2020, 10:53:04 AM by jeff3163 »
« Reply #14 on: June 07, 2020, 11:48:52 AM »
Yes Jeff that right , i don't understand when i read the README .txt ..  ;)
