......And I added Norm‘s suggested DXdiag TDR fix.
I cannot find NOrm's suggested DXdiag TDR fix....can you point me to that?
Thanks,
It was in another thread here:
„P3Dv4x and above on Win10 64bit, Nvidia GTX1080ti with latest drivers. It's called DXGI hung error.
The problem: an app called TDR checker monitors the computer’s hardware, particularly the GPU. When the GPU stops responding with the computer for 2 seconds TDR checker restarts the driver if GPU is under load; (It's like a time out - and if the app exceeds the time out the GPU graphics driver is stopped - then restarted.
But if you in an application like P3Dv4x+ the stopped driver results in "DXGI hung error".
(Display driver not responding)
https://www.pugetsystems.com/labs/hpc/Working-around-TDR-in-Windows-for-a-better-GPU-computing-experience-777/(If you don't get it that's a good thing!!). I haven't had it either ('Touch wood"!) but I just finished working on a guys PC in Florida yesterday am:. A fresh P3Dv5x install -(GPU GTX1080TI), and on first start this error).
So until HF2 is done for users that experience this fatal error in the sim: a fix that is supposed to work (But not exactly for the novice user to do), is to create a sub key:(TDS entry) in the windows registry to nullify the TDS timeout so that the graphics driver is not stopped).
Will post the method here but again not for novice PC users so please only implement if you know how and are ok with editing your registry.
How to:
- Exit all Windows based programs,
- Click on the Windows Start button, type regedit in the Search box,double-click regedit.exe from the results above. (If you are prompted for an administrator password or confirmation, type the password or provide confirmation).
- Browse to and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
- On the Edit menu, click New, and select the QWORD (64-bit) value from the drop-down menu,
- Type ‘TdrLevel’ as the Name and click Enter,
- Double-click TdrLevel and set the value as 0 (it is set to that by default, but double check) and click OK,
- Close the registry editor and restart your computer for the changes to take effect!
That should disable the TDR Detection/GPU Driver timeout.“
