Author Topic: Bid Problem  (Read 2015 times)
jmsmth
Bid Problem
« on: March 02, 2020, 02:31:14 PM »
I am trying to fly the first flight in Tour 39.  When I try to select it I am told it already exists in my bids.  I then checked "view my bids" in pilot center and it states I have not bid on any flights.  When I enter cigar box ant try to load flight data it says "try again".  There has to be a hang up somewhere.  I uninstalled cigar box and reinstalled it.  Same result.  Any suggestions?
Jim Smith MFC0010
Re: Bid Problem
« Reply #1 on: March 02, 2020, 03:40:14 PM »
Removed you off the tour to reset your status. You'll have to sign up again on #39 but now your bids should work.
jmsmth
Re: Bid Problem
« Reply #2 on: March 02, 2020, 03:47:17 PM »
Many thanks Norm.  What would we do without you?
Jim
jmsmth
Re: Bid Problem
« Reply #3 on: March 02, 2020, 03:56:00 PM »
Didn't work Norm.  Same thing.  I signed up again, selected flight.  Said bid already there.  Pilot center says no bids.  CIGAR Box says try again.
Jim
Re: Bid Problem
« Reply #4 on: March 02, 2020, 10:18:44 PM »
Jim
Well can verify that you have no bid in the system so something is obviously hung up somewhere on that 1st leg. Looks like there is NO aircraft assigned when you signed up hence the bid won't complete .
Will shoot you an email.. stand by.
« Last Edit: March 02, 2020, 10:22:29 PM by nbrich1 »
Re: Bid Problem
« Reply #5 on: March 03, 2020, 03:14:11 PM »
All fixed up now James -  (It was a BAD Bid in the database under your name but once it was deleted - all was freed up again!)
So you're back in business. Sorry for the delay but had to get that bid deleted out of the database before I could test and make sure that fixed you up. Now you're all good to go!
You're added to tour MFC0039 with your chosen aircraft set (D18S (Beech 18) and leg 01 has been bid and is ready to fly. (And I tested in Cigar Box - and bid generates without issue now.
So just fuel up and you're ready to go. lol.  Carry on sir.
