Author Topic: BWEP: Gates of the Arctic RELEASED!!  (Read 4304 times)
« on: December 04, 2019, 10:46:09 PM »
On the BWEP Page now, you can get the latest edition of Blue Wave Energy Partners Pipeline. Gate's of the Arctic. This journey will take you through some of the most breathtaking terrain but also some of the most beautiful scenery north of the Arctic Circle.
 It follows the BWEP Pipeline through the mountains and even crosses over the dangerous Atigun Pass. Helicopter and fixed wing pilots will be challenged up here.
 It's taken quite some time to get this edition of BWEP ready for prime time. I think the payoff is worth all the work it takes.
Hope you like it and please post some screenshots if you get the chance too. Here's a few I took:
« Last Edit: December 05, 2019, 11:14:30 AM by Bradallen43 »
Re: BWEP: Gates of the Arctic RELEASED!!
« Reply #1 on: December 06, 2019, 01:28:08 AM »
Beautiful Brad,
Great work on this huge project.....BWEP rocks!
« Reply #2 on: December 07, 2019, 08:20:06 AM »
Thanks, Brad for all your hard work on this. BWEP is one of RTMM's crowning jewels.  Great pics!
tomse
« Reply #3 on: December 11, 2019, 02:26:59 PM »
Yeah really a great work, a big project. Chapeau for your efforts. I followed the pipe up to Galbraith LAke apt and I found only one segment with misalignment at 5CD. No additional Mesh installed on my system, pure ORBX stuff.
Can anybody verify?
tomse
« Reply #4 on: December 11, 2019, 02:29:16 PM »
another view at 5CD as well
« Reply #5 on: December 11, 2019, 02:44:17 PM »
Hi Doc!!
Make sure you've disabled 5CD using the ORBX Vector Airport Elevation Correction utility found with Vector. Once you disable that airport, go back and check your pipes alignment. That should no longer be separated.
Here's a pic I just took at that same spot your picture was taken at. Using P3D and as you can see, no break with 5CD disabled using the Vector AEC utility.
« Last Edit: December 11, 2019, 02:53:18 PM by Bradallen43 »
tomse
« Reply #6 on: December 12, 2019, 04:59:32 AM »
Hm,
I have 5CD AEC disabled
I have the latest d/l of "Gates of the Arctic"
I have the latest d/l of BWEP airports (payware version)
I have global/ vector/ LC North America Alaska/ Canada
scenery order is ok
insertion point is ok
still FTX Central  3392 running
no additional mesh
no idea
« Reply #7 on: December 12, 2019, 05:17:06 AM »
Just checked the pipeline at 5CD. No problems found.
@Thomas, did you install the very latest version of BWEP airports (payware version), refreshed 12.11.2019?
« Reply #8 on: December 12, 2019, 05:23:36 AM »
I don't have any breaks here either.
tomse
« Reply #9 on: December 12, 2019, 07:41:17 AM »
Yes Dieter I did
« Reply #10 on: December 12, 2019, 04:05:18 PM »
On an unrelated issue that I see at 5CD and wondering if anyone else has these: flickering BWEP logo at the end of the tarmac. (I know what the issue is. The logo objects need to be raised a very small fraction off of ground level, easy to fix.)
Also there's a flickering area where the taxiway meets the runway.
I'm just wondering if anyone else sees these too.
« Last Edit: December 12, 2019, 04:13:19 PM by ualani »
rgerdes
« Reply #11 on: December 12, 2019, 05:09:10 PM »
I had the broken pipe segments too.
Finally figured out I some how got an earlier version.
Go to the BWEP page and re-download the "BWEP Gates of the Arctic v1"
The copy I got on 12/4/2019 didn't have the v1 in the title.
Comparing the Chandalar Shelf file in the two versions they are a different size so something changed when the official version was announced.
Bob
Update:
Ha, need to read Doug's NOTAMs ::)
I see that on the 6th there was an announcement about a bunch of BWEP fixes - including the Gates....
« Last Edit: December 12, 2019, 05:36:01 PM by rgerdes »
tomse
« Reply #12 on: December 14, 2019, 10:58:22 AM »
finally found the reason why
a scenery file called "5CD_Chandalar_Shelf_Test" was activated and interferred.
my stupidity :(
