Hmm a lot here. Once you login to MFC then the tour downloads are visible.
Tour 1 purpose is/was to get familiar with the site, the flights that are available to fly, flight bids, tours and tour legs, the downloads, (tours, flight plans and cigar box), as well as the cigar box use.
Tour 2 is hub tour of sorts: just around the neighborhood of Ketchikan and Misty's place which is the center or core locations of rtmm land. It all started in this location hence many Rtmm locations are in the vacinity.
The easiest is to put all the rtmm scenery locations in then there is no worry about checking what scenery is required for each tour. You need them to be able to see them!
There's many rtmm locations among the large operating area of Alaska, BC and more and over time am working to hit them all.
In addition to the over 400 tour legs in the tour excursions there is also over 700 single flights to rtmm locations that one can fly.
All to say, this is a big scenery packed site and full of information hence us does take an effort to get up and running but well worth it if you enjoy flying "bush" in the ruggedness of these areas.
MFC is the operational VA style module to capture your flights. Misty flying club but it is not exactly a simple VA with a-b routes. All of it is complex custom work in which to define and build and make flyable and is tailored to bush flying and rtmm scenery exploration.
MFC
