Author Topic: New Orbx FTX Central  (Read 10676 times)
Re: New Orbx FTX Central
« Reply #15 on: August 08, 2019, 09:11:39 AM »
Every thing has worked for me.  I don't know why some folks think they have to move everything.  I like the auto update thing.  I found three of my installs had updates that I didn't know about.  Time marches on!
Lazyeight
« Reply #16 on: August 10, 2019, 11:39:45 AM »
My first shot at installing Orbx FTX Central seemed to work fine. Everything opened up faster than in the past and solid FPS speeds. Then I noticed none of my RTMM scenery was showing. So, I began looking at insertion points. Then trouble began. My P3Dv 4.5 would not even open. After trying various changes nothing worked. I deleted ORBX Central and went back to FTX Central and it seems to be doing fine. I would like to use the new ORBX Central when I figure it out. Thanks
Lazyeight
xxd09
« Reply #17 on: September 06, 2019, 06:09:07 AM »
Anybody else working with Orbyx Central 4 v0.12?
There seems to have been a lot of updates to the original program over the last few days
I haven’t tried it yet as I have very functional FSX and P3Dv4.5 sims and scared to upset them!
Want new Sceneries though
xxd09
« Reply #18 on: September 06, 2019, 07:45:12 AM »
If your FTXCentral is workin ok:
No reason to change from FXTCentral3 to OrbxCentral now - no advantages at this time - constant improvements in the updates but still not completely "bugless".
« Last Edit: September 06, 2019, 11:33:59 AM by Dieter »
xxd09
« Reply #19 on: September 06, 2019, 11:35:07 AM »
Thanks Dieter-was my gut feeling confirmed by yourself with vastly more experience than me
Are you interested in any of the new Orbyx Sceneries only available via Central 4 ?
I will content myself with the splendid setup I currently have-off to fly the “new” RTMM BWEP “ updates of the Alaska pipeline!
 xxd09
« Reply #20 on: September 06, 2019, 12:49:15 PM »
If you're all splendid don't change it.  After lots of reading on it, it's definitely not worth the bang for the buck at this time.
xxd09
« Reply #21 on: September 13, 2019, 12:38:04 PM »
Orbyx Central v 0.13 released
Appreciate anybody’s experience with this latest Update
xxd09
« Reply #22 on: September 13, 2019, 04:23:49 PM »
I just took it through the paces, insertion point etc. and it works well for me.  No complaints.
rgerdes
« Reply #23 on: September 14, 2019, 02:21:03 PM »
I was updated to the 0.13 version (on Friday the 13th :() and checked insertion points and all was well.
This morning I noticed ORBX Global Vector was no longer working.
Long story short I finally uninstalled it and reinstalled into the main folder - got it back but now I have to disable all the elevation problems again. Is there a list here on RTMM of the airports that need to be disabled?
Bob
« Reply #24 on: September 14, 2019, 03:27:43 PM »
Hi Bob, You should run the Vector Auto Config after any install or removal of scenery.  There's a little notice on the tab for airport elevation corrections.
rgerdes
« Reply #25 on: September 14, 2019, 06:25:13 PM »
Thanks Dex
A few others I remembered are the BWEP list.
PAVS (Sparrevohn LRRS Airport) is another.
Bob
xxd09
« Reply #26 on: September 18, 2019, 03:54:31 AM »
Bit the bullet and installed Orbx Central last night
Followed all the instructions as they arose
All updates done All Sceneries in order
All good
Whew!
xxd09
« Last Edit: September 18, 2019, 08:17:27 AM by xxd09 »
« Reply #27 on: November 25, 2019, 12:20:04 PM »
Bueno chico   ;)
« Reply #28 on: November 25, 2019, 07:27:24 PM »
Whew lucky guy! Most aren't so fortunate as the new central so far has been known to destroy scenery.cfg files has a tendancy to eat scenery entries if it is not done exactly right lol. (And never uninstall FTX Central 3 before putting on ORBX Central (which is v4x).
