Author Topic: BWEP pipeline  (Read 3805 times)
xxd09
BWEP pipeline
« on: September 15, 2019, 06:49:02 AM »
Put in the new RTMM Libraries
Noted that non apposition of pipeline has reappeared at Valdez
Using appropriate library with Orbyx Valdez
I had this a year or two ago and cured it but cannot remember how
Help!
xxd09
Re: BWEP pipeline
« Reply #1 on: September 15, 2019, 08:37:42 AM »
     If you're saying the pipe segments are disjointed in spots, that is usually a mesh issue.  What mesh do you use?
     You could search for your previous posts, if you had a thread for it a couple years ago.
https://forum.mistymoorings.com/index.php?topic=3291.msg28455#msg28455   ;)
« Last Edit: September 15, 2019, 08:49:37 AM by jeff3163 »
xxd09
Re: BWEP pipeline
« Reply #2 on: September 15, 2019, 10:57:08 AM »
Thanks for that-it was Pilots Mesh 2010 then-disabling it did the trick
I do not have Pilots Mesh installed now
Was 2cm in Display Options -changed to 5cm -no difference
No breaks in pipe after Thompson’s Pass airstrip to Copper Bend .Donnelys Dome Airport pipeline OK
An Orbyx Valdez Scenery anomaly?
xxd09
