SDT Problem at Nome - There is a difference between P3D V3 and V4 autogen. STD-2B looked perfect in V3 ... (with IS3, it was built in V3). However, V4 puts in different autogen buildings and in different positions ... the SDT objects where being overwritten by the V4 autogen. To solve this, I moved all of the Alaska Airlines and Snow Dog Tours objects to an area where no autogen for either V3 or V4 comes up. So this problem is solved. To get it, you need to redownload Snow Dog Tours and put in the new SDT-2 "b" group. If you are using "a" there is no difference. Here's the new layout for Nome.
PS ... to know if any update is for YOU, click on the refreshed date for the location. The
Location Maintenance Table comes up. In this case, it tells you a change was made in SDT-2B ... so if you are using 2A, you do not need to redownload. Let the maintenance table tell you what's happening. Any change like this is also on the
Site Maintenance Page. You can always peruse the Site Maintenance Table to see any and all changes being made on the site. This is a handy way to keep up to date.
Also, anything you see in
RED means if you want the change, then you must re-download the file.
