Author Topic: BWEP readme  (Read 3659 times)
xxd09
BWEP readme
« on: August 10, 2019, 02:47:35 PM »
Is it just me but I cannot get my BWEP readme file to open
Required to let previous owners of the BWEP files how to change to the new format
xxd09
Re: BWEP readme
« Reply #1 on: August 13, 2019, 08:13:08 AM »
If you're talking about the NOTAM readme at the very top of the BWEP page, then yes it points to a dead link. Doug??
Re: BWEP readme
« Reply #2 on: August 13, 2019, 12:15:01 PM »
Hmm ... strange, when clicking on "Read Me" at BWEP page I get this:
https://return.mistymoorings.com/bwep/docs/NOTAM%20-%20For%20Previously%20Installed%20BWEP.pdf
xxd09
Re: BWEP readme
« Reply #3 on: August 13, 2019, 12:56:47 PM »
Is the Readme now redundant?
xxd09
Re: BWEP readme
« Reply #4 on: August 13, 2019, 01:42:10 PM »
This "ReadMe" is very important, everybody who intends to install the latest updated BWEP-sceneries must follow these instructions!
« Last Edit: August 14, 2019, 06:00:47 AM by Dieter »
Re: BWEP readme
« Reply #5 on: August 13, 2019, 04:23:05 PM »
Interesting. When I copy the link at the top of the page, the address is https://return.mistymoorings.com/bwep/docs/NOTAM%20-%20For%20Previously%20Installed%20BWEP.txt, not .PDF. I get a 404 message.
Re: BWEP readme
« Reply #6 on: August 13, 2019, 08:14:07 PM »
     When I clicked on Dieter's link another tab opened in my browser with a pdf displayed on it.  Seems to work for me.  :P
     I just checked the link itself, clicking on it.  It works for me also.   :o
The "Readme" in question says this: (looks better though.)  ;)
NOTE: If you DO NOT have the BWEP pipeline project installed, then you may
safely disregard this Read Me.
READ ME: GUIDANCE TO UPDATE BWEP PIPELINE INSTALLATIONS PRIOR TO 29 JULY 2019
The guidance given herein is for users who already have the BWEP pipeline
project installed and wish to update their files.
“DELETING”
To properly update your files, it is essential to DELETE the 5 folders listed
below because some file names have not changed in the update and you will see
‘double objects’ if you simply ‘overwrite’ them. ‘Deleting’ these folders
ensures you will not experience this.
 BWEP Richardson Highway_01.27.2017
 BWEP SAK_02.06.2017
 RTMM BWEP Dalton Highway
 RTMM BWEP SAK v2 for PAVD
 RTMM BWEP The Interior
Preferred method:
 delete these folders from the Scenery Library in the sim
 delete these folders from where you have them stored
DOWNLOAD and ADD
After you have deleted the folders using the method described above, download
the 5 ‘zip’ files listed below from the BWEP page and extract the contents to
where you store your add on scenery folders.
 BWEP Airports*
 BWEP SAK Pipeline
 BWEP The Interior
 BWEP Dalton Highway
* You will need to select package ‘A’ or ‘B’ [see guidance on the BWEP page
as to which package to download].
Add the new scenery folders to your sim’s Addon Scenery\RTMM\ folder and the
Scenery Library. ‘Activate’ by starting your sim.
BWEP OBJECT LIBRARY
Check that you have the BWEP Object Library [30 May 2017] installed, if not,
it can be downloaded from the BWEP page.
BWEP PAGE https://return.mistymoorings.com/bwep/index.php
« Last Edit: August 13, 2019, 08:25:21 PM by jeff3163 »
xxd09
Re: BWEP readme
« Reply #7 on: August 14, 2019, 02:30:49 AM »
Dieters link worked for me
Thanks-Dieter
xxd09
Re: BWEP readme
« Reply #8 on: August 14, 2019, 07:06:53 AM »
Dieter's link works, but the link that I referenced above still gives me a 404. I tried it using 2 different browsers as well as tried it on my phone. No good.
