Author Topic: Problem with Misty Flying Club  (Read 3090 times)
wschneid
« on: July 15, 2019, 10:28:53 AM »
I have completed the Barnstormers tour and am trying to do the next tour, Short field Glacier.
When I tried to submit my bid, it told me that the bid had already been sent, but when I went to Cigar Box to do the flight, it could not find the schedule. I went back to Misty Flying Club and checked my bids and it show no bids submitted. What's going on.
I followed the directions about submitting a bid, but when I go into Cigar Box and try to Get flight Data, I get a Try Again message
« Last Edit: July 15, 2019, 11:33:11 AM by wschneid »
Re: Problem with Misty Flying Club
« Reply #1 on: July 15, 2019, 04:59:33 PM »
Give me a minute Bill.. will remove you from that tour MFC 0006 and you can re-add yourself. Looks like the aircraft didn't take when you joined. Now you're removed.  Try to sign up on that tour a-new with your desired aircraft selected. Once joined, try leg one again to see if it generates correctly for you. If not just yell.
wschneid
« Reply #2 on: July 17, 2019, 09:24:31 AM »
Tried that, Norm, but same result. I'm flying the C47 Skytrain. I chose that airplane when I opened that tour, Shortfield Glacier. Loaded the flightplan from the site. Went to the airfield (PF20), set the parking brake and opened Cigar Box. Clicked on Get Flight Data it tells me "Try Again". When I went back into Misty Flying Club site and select the first flight (PF20 to NVMAN), it tell me that flight is in my bids, but when I look in "My Bids" it does show anything.
Help. I like the site and the first two tours went well.
wschneid
« Reply #3 on: July 17, 2019, 12:19:14 PM »
Working on it Sir William - see my email.
wschneid
« Reply #4 on: July 20, 2019, 09:30:33 AM »
Norm,
I haven't seen any email. What's up?
wschneider
« Reply #5 on: July 20, 2019, 03:57:11 PM »
I used same email as you registered at MFC. Might be in your junk folder..  still working on it. Might have to change up your password so I can try a few things to try to get you running on that tour but am away from PC for a couple of days. Try to sign onto your 7 and see if leg 1 will generate for you on that tihr. W Norm
wschneid
« Reply #6 on: July 21, 2019, 09:09:10 AM »
Norm,
Looks like its working now. I completed the first flight of the Short Field Glacier Tour.
Bill Schneider
« Reply #7 on: July 21, 2019, 09:21:48 AM »
Yup I see the pirep.. good. Will keep looking as to why it wouldn't complete the bid but the site does get hung up in processing at times. It might have hung up for some reason - queue perhaps but finally corrected itself.  Glad its working now.
« Last Edit: July 22, 2019, 10:25:57 AM by nbrich1 »
