Author Topic: Maintenance Logs for Scenery Locations  (Read 490 times)
« on: April 09, 2019, 08:56:13 AM »
Each scenery location now has its own "maintenance log." Any time a change is made on that scenery location, you will be able to see what change was made and who made the change.
To see the log, you click on the DATE for the location (Refreshed/Updated/Added). All of these are now hot linked to a location-specific maintenance log.
Literally, we are almost daily making adjustments in the locations. With many people flying RTMM, any problems hopefully are reported on the forum. We can then go after these, fix them, and now DOCUMENT them.
The logs will be cumulative ... the next "fix" will be listed right under the last one with the date and the person's name making the fix. So these, later, will look like a history for the location. This is all part of the 2019 REFRESH project that we are doing.
All of the logs are now in place.
Re: Maintenance Logs for Scenery Locations
« Reply #1 on: June 17, 2019, 09:59:59 AM »
All Maintenance logs are "in place" for ALL RTMM LOCATIONS.  Also, for each location, in it's /scenery folder (where the bgls reside), there is a "version.txt" file. You can open it with notepad and see the contents. It is only a COPY/PASTE of the top part of the "header" for the location on the scenery page. It has the date and the author information on the location. (Not the start locations). If you are curious if you are up to date, the version.txt you have should match the header on the scenery page ... check the dates.
