Author Topic: SCENERY.DAT file error  (Read 3893 times)
scanham
« on: March 26, 2019, 04:56:09 PM »
I have the latest UPDATE for RTMM required  FSXP3D Libraries Part IV_3.21.19  installed.
When I installed the add-on scenery Ocean Falls today, I got the following error when I start up FSX-SE:
SCENERY.DAT file error.  Close Flight Simulator and
delete 'addon scenery\rtmm\object libraries\ez
scenery libraryfsxp3d\scenery\fsxp3d lfwwkbr1'.
Click OK to continue.
Steve Canham
MFC0077
Re: SCENERY.DAT file error
« Reply #1 on: March 27, 2019, 12:10:50 AM »
I'm guessing that you deleted fsxp3d lfwwkbr1 from your HDD and didn't remove it from the scenery library list in FSXSE. If so, one way to fix it is:
Restore the deleted file from your recycle bin, run FSXSE, remove it from your scenery library list and then delete it again from your HDD.
scanham
« Reply #2 on: March 27, 2019, 07:47:54 AM »
Hi Steve,
Thanks for your response.
I checked my objects library (EZ Scenery Library) and have fsxp3d lfwwkbr1.bgl and fsxp3d lfwwkbr1.txt, so it wasn't removed from my HDD.
Any other ideas?
Steve Canham
MFC0077
« Reply #3 on: March 27, 2019, 10:38:00 AM »
Check your scenery path in the scenery library. It should look very similar to this:
Addon Scenery\RTMM Required Libraries Part I\EZ Scenery LibraryFSXP3D 6-7-14\EZ Scenery LibraryFSXP3D\scenery
Check that your fore slashes properly separate all of the folders and sub folders.
« Last Edit: March 27, 2019, 10:46:59 AM by ualani »
scanham
« Reply #4 on: March 27, 2019, 12:26:29 PM »
After several reboots, it appears that the scenery was re-indexed and the error has disappeared.  Not sure why that wasn't happening for me yesterday, because I'm fairly certain that I did a re-boot, which is my "go-to solution" for most any computer problem. :)
Thanks for your time Steve!
Steve Canham
MFC0077
« Reply #5 on: March 28, 2019, 06:58:38 AM »
Strange one, but glad you got it working properly!
