Author Topic: Misty aircraft Repaints  (Read 2120 times)
jmsmth
« on: March 24, 2018, 10:47:51 AM »
I am having trouble installing the C185 repaints.  I have the first one installed but according to the readme to install the others you need to copy a series of files to a folder on your desktop.  When I highlight these files in the readme for transfer they will not paste.  Are the files actually located elsewhere?  If so where?
Jim Smith
Re: Misty aircraft Repaints
« Reply #1 on: March 24, 2018, 11:05:23 AM »
No James.. these should be standard paint texture folders for carenado c185 and the txt file for the aircraft.cfg. I can take a peek.. which on are you trying?
jmsmth
« Reply #2 on: March 24, 2018, 01:34:02 PM »
I have added the Skywagon Misty Taxi to the C185 Amphibian folder.  The readme then says "To use this paint with the Ski, Float or tundra create a folder on your desktop called misty paint.  copy and paste the following files."  Then 21 files beginning with Care185Fuse_A through Carel185_G_Bump.  When I highlight them and select copy they will not paste to the misty paint folder on desktop.  As a matter of fact they will not paste anywhere.
Jim Smith
« Reply #3 on: March 24, 2018, 03:07:36 PM »
Ok James...
What Chris has done is made one livery for the Amphibian 185 only. But for the others you have to make your own: with a few of his files plus some others.. IE: for the Ski, Float or Tundra.
Np James.. just put in the Misty 185 livery in the folder to the amphibian version for now and I'll set up the other liveries for you in the next few days and get them to you. Just a bit of file playing assembly work .. but not a biggy.
jmsmth
« Reply #4 on: March 24, 2018, 04:46:44 PM »
Thanks Norm.  Really appreciate it.
Jim
« Reply #5 on: March 24, 2018, 06:00:29 PM »
All good James and no problem sir.
