Author Topic: Blue Wave Energy Partners - is LIVE!  (Read 256964 times)
Re: Blue Wave Energy Partners - is LIVE!
« Reply #75 on: November 14, 2016, 07:48:09 PM »
Hi ... good catch. Originally, we were going to put out the airports "separately" and as we were building them, we were adding them to a zip. This would then fix up the airports along the way. Since that time, we decided to put the "fixed up" and "added" airports to the download for each pipeline section. So the airports for BWEP SAK, are already in the download.  We will be doing the same for BWEP Richardson Highway when it is released.  I've change that instruction on that dispatch so it doesn't call for the addition airport zip download (which doesn't exist anymore).
Thank you
« Reply #76 on: November 15, 2016, 02:30:50 AM »
 OK, thanks Doug.
 LOL
RCFlyer
« Reply #77 on: December 01, 2016, 05:36:16 PM »
Have been flying P001M, oil leak, dispatch and have not been able to see the oil leak.  I have used the scenery checker and have verified that I can see the BWEP objects.  I have flown the route both ways multiple times, flying at less than 100 feet AGL down the middle of the pipeline service road, with an airspeed of around 35 knots.
I have used the Dispatch Selector to activate the P001M dispatch (it is listed in the green Active Dispatches section).  My flight sim is P3Dv3.4.
Any suggestions????
Regards,
Danny
« Reply #78 on: December 04, 2016, 11:10:32 AM »
BWEP`s fleet is growing again.....
We have a new Helo....the payware Milviz MD530F in the the BWEP Hangar.
This small, fast and agile bird is very good for lowlevel inspction lights along the Pipeline.
Here it is in base configuration...
« Reply #79 on: December 04, 2016, 11:13:23 AM »
For patrol flights inthe Valdez Harbor Area it`s fitted with emergency floats.....
« Reply #80 on: December 04, 2016, 11:16:05 AM »
Alaskan winterseason is Long and the days and nights are dark.....
No Matter, the Littlebird is equipped with a strong nightsun light......
« Reply #81 on: December 04, 2016, 11:19:00 AM »
...and as internal cargo capacity is limited...you can attach an external cargo pod.
But you have also a cargo hook for slingloading attached.
« Reply #82 on: December 04, 2016, 11:22:57 AM »
The Milviz MD530F is "up" on the BWEP page. At the bottom of the repaints in slot #27.  Thank you Klaus!
Trex3D
« Reply #83 on: December 04, 2016, 03:35:36 PM »
Way too cool! Thanks Klaus and Doug  :o 8)
« Reply #84 on: December 14, 2016, 02:32:50 PM »
New BWEP chart now posted.. (thanks for on-the-way file listings). Is it possible to add file issue date as was indicated on the previous table? On the previous table format issue date was reflected so all would know at a glance if an updated file was required or we already had the current file. On the new table files without file date of issue, there is no way to know if a file has been updated or if we already have the current file.
Just a thought. Thanks in advance for your consideration.
« Reply #85 on: December 14, 2016, 02:33:59 PM »
Norm, take a look now, I added the date column to the right. That's a good idea.
« Last Edit: December 14, 2016, 02:54:40 PM by Doug »
« Reply #86 on: December 14, 2016, 05:56:03 PM »
 Very nice new chart !
 Waiting for the Richardson Highway section with great anticipation!
« Reply #87 on: December 14, 2016, 07:47:06 PM »
Thanks Sue.  It will be a great section, lots to see and do.
« Reply #88 on: December 14, 2016, 09:38:19 PM »
Excellent Doug - the dates clarify it all. Thank-you.
THibben
« Reply #89 on: December 16, 2016, 04:45:02 PM »
I am at a loss.  After finally getting a complete, and correct, instl of my scenery library I have been working on installing all of the objects required in the RTMM scenery object tester.
I have managed to install all objects except for the Alaska Power project (#11) and the Blue Wave Energy Partners (#12)  I have been working on those nearly all day.  I thought I have been
following the instruction exactly but nothing is showing up in the tester.
Any thoughts would be appreciated.  Before I had this major repair to my scenery library everything was working fine.
Tom
Tom
