Folks,
I'm making good progress but wanted to update the way this will probably play out. There will need to be two versions of BWEP for Southern Alaska. The reason is that the breaks in the pipeline go far beyond the Valdez area. I'm now in the Thompson Pass area and still discovering elevation breaks along the pipe.
So, it won't just be a couple of files you replace with updates. It will need to be a complete installation package where you choose which one. Either SAK with default PAVD or SAK with the new PAVD airport by ORBX.
If you currently have the default SAK edition, then once you see that I've completed the new PAVD airport version, if you have the new payware airport or are planning on getting it, you'll need to delete the default SAK edition and replace with the updated PAVD Edition. If you're not going to buy the new ORBX airport for SAK, then you can leave your current installation alone.
