Hello
I am converting to P3Dv3 as quickly as possible. With only SAK missing from ORBX most requirements are met. Tongass, is working...it took a bit, but it is working...so far...so good. Since this is a new installation, I decided to install RTMM from scratch. The Object tester revealed everything, except the yellow smoke. I double checked, and the library is there, just not the smoke. Misty's place is working just fine, so is Herring Bay, but things like Aiken is not. It doesn't show up in the "go to airport" and if I fly over, it's not there. but why? Did I do something wrong, or are some of the destinations just not P3Dv3 ready?
Having Misty's place working means I can fly the Alaska Adventure PNW to Misty's place, so I will give it a try, but I am anxious to get all of Misty working in P3Dv3 and get rid of all the rest.
You help and advice is appreciated....
Henry
