Hollis Harbor Update Patch by Rod JacksonThis is a patch to update Hollis Harbor v1.0 to v1.1. You need to have already installed Hollis Harbor v1.0 to use this patch. This patch does the following things at Hollis:
1. Replaces buildings at the Ferrry Landing in Hollis and the Wolf Creek Boathouse area which could be seen in FSX but not in P3Dv2
2. Replaces the ice in Hollis Harbor with ice that eliminates the problem that some users have had with trees in the water when the CVX_Hollis_Harbor_Ice.bgl was active. For those of you who had added a .off to the ice file, just delete that file before copying this patch. If you still don't wan't the ice to show up, you can still add an .off to the end of the reivsed CVX_Hollis_Harbor_Ice.bgl.
3. Corrects a file with missing objects that is only used by those who have ORBX PAKT installed. Some of you will already have this correction.
4. Adds a beacon on top of the hill to the North of Hollis Island. The frequency is 621. The ID is HHB. The morse code is .... .... _ ...
5. Adds a Fuel Trigger at the Eagle Air Dock.
6. Provides an updated v1.1 User Guide that reflects the above changes.
7. Adds a windsock that is only erected temporarily each summer at the Hollis (summer only) airfield.
8. Makes a few corrections to objects displayed during Summer and Spring season.
Follow the instructions in the README carefully ... the update steps are clearly stated. Thank you Rod for this fine update to an already excellent Scenery Area!
This is now available under "H" for Hollis Harbor on the Scenery Page.
Comment on this News Item HERE
