Author Topic: SAK Eldred Rock - A heli-lovers dream  (Read 3261 times)
« on: April 02, 2013, 05:19:20 PM »
Hi,
for all heli-lovers just thinking SAK is only made for the fixedwinged.
Look, this is Eldred Rock located in Lynn Canal between Juneau and Skagway....Is that a beautiful landingspot for helicopters?
Lipra
Re: SAK Eldred Rock - A heli-lovers dream
« Reply #1 on: April 07, 2013, 05:25:04 AM »
corbu1 where did you get the heli trim gauge. I'm trying to get to grips with helicopters and I think this may help
retep49
  • Daily Flightsimmer
« Reply #2 on: April 09, 2013, 03:04:06 AM »
Lipra, look here http://www.dirkfassbender.de/autopilot.html
I use this autopilot for many years now, and I have installed this in every helicopter.
I have 18 different type's of helicopters in my hangar.
If you have any trouble to install just send me a PM, and I will help you.
Peter
« Reply #3 on: April 09, 2013, 02:43:59 PM »
Hi Lipra,
you can get the helicopter trim gauge here:
http://library.avsim.net/search.php?SearchTerm=helitrim.zip&CatID=root&Cookie=1
or Login the AVSIM library and search for helicopter trim gauge.
It doesn`t work like e real world helo force trim, but for fsx it works quite well.
I forced it`s fsx slaved Buttons to one of my Saitek X52 coolie hat`s. So I can control trim via Joystick.
The Panel helps reading out your actual trimm Settings.
If you own fsuipc payware Version, there`s also a heli trim System implemented. You can read fsuipc Manual to learn using it. But this trim System has no gauge Panel. That is the reason I don`t use this one.
Dirk Fassbender`s Autopilot is something completly different. As it`s name suggests, it`s an autopilotsystem with a wide range of functions e.g. auto-hover. It works like a dream and is very well known by fsx helisimmers. I also use it on some helos in fsx, but not with the Nemeth AS350 which I took the screenies above.
