Author Topic: Do you want to customize FSX?  (Read 29083 times)
« on: February 09, 2011, 06:46:01 PM »
Adventurous, curious, want everything in one place?  If you have not heard of this utility program you may want to try it.  The FSX version is like a Swiss Army Knife for the sim.  You can modify the FSX.cfg with 22 different categories.  Aircraft.cfg has 24 categories.  14 categories for the Panel.cfg.  Flight files with 5 categories.  6 for AI traffic.  There are 13 in the Others section. Last but not least it even has a section to let you create your own functions.  Oh yeah it also has a CFG Editor and an XML-Editor included.  What is it you ask?
Flusifix-2006 v5.0 is the program and all the tweaks and twits and fixes you see scattered around the web are able to be done in one program.  The good part is it is FREE.  Where is it you say?  Just use the link below and when the page comes up it will be in German, if you don't Spechen ze .... just look on the right side of the page and click on the Union Jack for English.  There is also a version for FS9 but last time I looked it was in German only, although I had a translation for it.
Enough yammering you say, where can I get it?
Rightcher!:
http://www.wolfgang-picheta.de/
Try it you will like it.
Here is the info from the download site as to what it does.
All functions of the FlusiFix-2006
    * FSX.CFG
          o FSX.cfg reset: resets the FS9.cfg (and Standard.xml) into the original state
          o Start flight: selecting a new start flight
          o Joystick sensitivity: adapts badly calibrateable joysticks
          o Reverse thrust reaction: corrects reverse thrust dropouts
          o Aircraft folder: searching for new aircraft folders
          o Welcome screen: activates/deactivates the welcome screen
          o Status lines: activates/deactivates the lines for park brake, stall, overspeed ...
          o Flight tips: switches off the flight tips of the virtual co-pilot
          o Aircraft captions: extends the inscription of the AI aircrafts
          o Measuring units: specific country settings
          o FPS-display: extends the FPS display
          o Change of Views: change the different views time
          o Runway lights: corrects too large runway lights
          o Widescreen mode: activates/deactivates the widescreen mode
          o DirectX mode: activates/deactivates the DX9/DX10 mode
          o Performance 1-7: seven tips to incrase the performance - Performance 5 in V5.0 reworked
    * AIRCRAFT.CFG
          o Wing Leveler (LVL): deactivates the automatic turning on of LVL in the autopilot
          o ILS sensitivity: improves the reaction of the autopilot to ILS frequencies
          o Strobe Lights correction: adds the strobe ligths to the Learjet
          o Air Resistance: reduces the air resistance of the aircrafts
          o Exhaust effects Stock: adds exhaust-effects in the FSX stock aircrafts
          o Exhaust effects Addons: adds exhaust-effects in the addon aircrafts
          o Battery discharge: corrects faulty battery unloading
          o Touchdown effects: adds missing landing/touchdown effects
          o Frequency input: corrects faulty entries in the radio-stack
          o Vertical Shimmying: eliminates vertical whipping of the aircraft
          o Sideways Shimmying: eliminates lateral rolling of the aircraft
          o ATC Flight Number: selecting a flight number for the own aircraft
          o Yaw Damper: activates/deactivates the Yaw damper
          o Reverse Thrust performance: corrects the reverse thrust performance
          o Throttle Lever reaction: corrects faulty reaction of some throttle levers
          o Attitude of the B747: corrects the attitude of the B747
          o Lights of the B747: adds and corrects the lights of the 747
          o Contrails: insert new contrails
          o Liverie-Check: extensive error check of the fltsim-sections
          o Aircraft manufacturer: correcting wrong manufacturer entries in the Fltsim-sections
          o ATC-Parking-Types 1: detect missing parking entries in the Fltsim-sections and correct them
          o ATC-Parking-Types 2: searching for false parking ATC-type variables
          o Doors of the 737/747: correcting of the doors for the default B737/B747
          o Fly By Wire: activates/deactivates FBW function
    * PANEL.CFG
          o Mooney Bravo: adds a new fuel-tank-selector-switch and the ADF announcement
          o Mini panel: activates/deactivates too large mini panels
          o GPS Retrofit: adds missing GPS window
          o GPS Exchange: chanching GPS295 to GPS500
          o GPS GPS Window Size: changes the window size of GPS
          o GPS Window Position: change the GPS position on the screen
          o TCAS Retrofit: add a TCAS window - in V5.0 reworked
          o TCAS Window Position: change the TCAS position on the screen
          o RADAR Retrofit: add a RADAR window - in V5.0 reworked
          o RADAR Window Position: change the RADAR position on the screen
          o Altitude Callout Retrofit: adds the altitude callout
          o Altitude Callout Sound Selection: selecting callout sounds
          o MFP Retrofit: add a "Multi Functions Panel" window
          o MFP Window Position: change the MFP position on the screen
    * FLIGHT FILES
          o Axis Indicators: activates/deactivates the axis indicator
          o OMI Marker Sound: activates/deactivates sound in the radio stack
          o EFIS Activation: activates/deactivates the EFIS
          o Outside View: puts quick crossing into the outside view
          o Aircraft Trim: corrects the aircraft trimming
    * AI-TRAFFIC
          o Aircraft Selection: excludes/permits AI-aircrafts of the aircraft-select-menu
          o Exhaust Effect: adds exhaust effects to AI-aircrafts
          o Standard AI Traffic: activates/deactivates the stock traffic
          o Carspeed: decrases the speed of ground vehicles
          o Taxispeed: increases the speed of AI-aircrafts on the taxiway/runway
          o Traffic-Manager: setting new values for all traffic areas
    * OTHERS
          o Airlines.cfg: extends the Airlines.cfg with missing airlines
          o Strobes and Beacon lights: improves the flash rhythm of the lights
          o Fuel Calculator: a small fuel planner
          o Gauge cleaner: finds redundant gauges
          o Gauge Finder: finds missing gauges
          o Default Keyboard Commands: prints the stock key commands
          o Own Keyboard Assignments: prints the own key assignment
          o Calculator: a calculator to convert most diverse units
          o Power Masts: reduce green stretches under the power line masts
          o Rewards/Log book: saving Log book and Rewards
          o Thumbnail viewer: view the preview images for the various aircraft textures
          o Snow effect: decrased the snow effect on taxiway/runway
          o GPWS Call outs: deactivate/activate the GPWS Call outs
    * OWN FUNCTIONS
          o With this function generator !expert! users can generate up to 100 own adjustments
    * FSX-EDITOR
          o This editor is a little helper for implementing easy and quick changes to FS9 files like panel.cfg, aircraft.cfg and so on. You do not have to search through all folders since all relevant files are shown in an selection window.
    * XML-EDITOR
          o With this editor one can easily create or edit Gauges and other XML files.
    * MENU - PROGRAM
          o System-Infos: displays important information concerning FSX and the computer - in V5.0 reworked
    * MENU - OPTIONS
          o Log-Datei: clear FlusiFix log file
          o Language: change the language (german/english)
« Last Edit: February 09, 2011, 06:49:41 PM by spud »
Francois
  • FS Veteran
    • former FSAddon Publishing
Re: Do you want to customize FSX?
« Reply #1 on: February 10, 2011, 03:24:18 AM »
Yes, nice program. We (Bush Pilots) gave it an award back in 2007 already  :)
Francois A. 'Navman' Dumas
... and the man's blog
« Reply #2 on: February 10, 2011, 08:08:32 AM »
I'm afraid of 90% of it! :-)   Don't know what all that stuff does. But one thing I did try was the wing leveler program.  I have the WL utility and have used it.  But on the new FSX Real Air Scout, they put in a ROL feature that, with that autopilot, not only locks you from turning if you have the altitude set, it CANNOT be turned off in any way. (Rob, their tech there told me this).  But guess what? The WL in this little program nailed it. I can now set my altitude at 1200 feet and make turns.  Wonder what else it does? (Going to set a resume point first!) :-)  Now I have my Scout Amphib back!
Avian
« Reply #3 on: February 10, 2011, 10:55:51 AM »
This is an outstanding bit of freeware! FSX is already running better under it. Thanks for posting it Spud.
« Reply #4 on: February 10, 2011, 11:16:20 AM »
What "tweaks" did you make? Just curious. .....
Avian
« Reply #5 on: February 10, 2011, 11:36:49 AM »
Blimey, I dunno! Most of 'em!! :)
I increased the speed of the AI taxiing, I checked for missing textures models etc and fixed a few problems.
Increased the Contrail persistence (but it's cloudy so I didn't see anything yet)
added smoke to the AI.
reduced the autogen buildings per cell, (I had already done it for the trees)
put in the lowest highest and average FPS counter
these are just the things I remember, after all they are all returnable to default and there is a pretty good explanation with each one as to what it does. It's the best FSX tweaking utility I have ever seen I am surprised it has been around for so long without seeing any reference to it on other forums.
