As the first two scenery files with season switching capability are about to be released along with the switcher .exe program to change some the textures to a different season I thought I would post a screen shot of how I have my RTMM scenery setup in the sim. I am not entertaining suggestions on how I could be more efficient a do it easier. I use this method, have done so for many different sceneries that have multiple folders and will continue to do so. There are going to be questions about exactly how you need to set up the seasonal sceneries and there is a exact method that has to be used and if you don't you risk mucking up unrelated scenery, including payware.
The Season Switcher v3.0 MUST be placed into a 'parent folder' and those RTMM sceneries that have a season switching capability have to be inside this 'parent folder'. At the moment there are only two RTMM sceneries that meet this criteria so it is a matter of making a 'parent folder' placing the switcher within that folder. The putting any RTMM scenery folder with the seasons inside the 'parent folder'.
Here is an example:
NOTE that inside the FSX\Addon Scenery folder I have created my 'parent folder' I named mine Misty Moorings.
This is where I have placed the RTMM v3.0 Season Switch.exe file. I then made a shotcut on my desktop to the Season Switcher file.
Now, inside the Misty Moorings 'parent folder' I have each of my RTMM sceneries, each in their own respective folders with an MM prefix to remind me that they are Misty Moorings scenery. This is how I name my stuff you can use whatever name you like of course. The main point being is that you have to make a 'parent folder' and place any RTMM scenery that has the season switching capability inside this 'parent folder' as shown, no OPTIONS. Of course you do not have to put all your RTMM scenery folders inside the 'parent folder' like I do, I just like all my "stuff" together. Only those scenery folders that have the season changing capability are required to be inside the 'parent folder'.
When you are in the FSX Addon Scenery folder and right click, select NEW, Folder and then name your 'parent folder' what you like, it is up to you. Remember with the season scenery set up as required this way when you are in FSX and want to add that scenery you will double left click on the Addon Scenery folder, find the 'parent folder' and double left click that as well. Then you will see the RTMM scenery folder you placed in the 'parent folder' and select it with a single left click then click OK to add it to your FSX Library.
(Click on the screen shot to enlarge)
