Right then, time for more work-in-progress...
I have "solved" my issues with flattens - for the time being at least. Who knows what the morning will bring?
In order to make it more real, I have had to make two AFX... bgl files - one for the big helipad, which is higher up the slope. I still have some repositioning to do after the flattens - as you can see, the fence needs straightening. At least the main huts are on the level and I have managed to smooth the apron in front of the huts for parking and refuelling. I need to add a Jet A bowser / tank for the big heli pad.
Then there's the two outposts that need supplying - the one location has such powerful radiation that the helis have to land a short way away. Someone thought it might be cool to listen out to what the Canuckies are chattering about, the other side of that big bad border.
The other radio mast is merely for rebroadcasting stuff from space...
As for that little shack up the glacier, hidden behind those large rocks... weeelll, old One-Eye is in to a bit of home brew since he had to bury "Emma". The grave is still there, waiting for the exhumation and resurrection of our favourite little airfield. If you look closely, you will see old One-Eye himself, checking the fire under his latest brew of #5 special. He borrowed the recipe from Uncle Elmer and made a small change. You probably didn't realise it, but glacier water is sooo much better for the brewin' and a stillin' of the good stuff.
It's taking shape...
