Author Topic: RTMM.DAT for FSDiscover link not working  (Read 3555 times)
alpha117
« on: August 24, 2011, 12:05:59 PM »
Guys
I've tried the links, but just get 404 error, please can you provide a working link.
Many Thanks
Re: RTMM.DAT for FSDiscover link not working
« Reply #1 on: August 24, 2011, 06:04:10 PM »
I'm showing now problems on the website side.
« Reply #2 on: August 24, 2011, 08:00:34 PM »
I concur.  Neither link works.  I even tried "save target as", but it couldn't be done.  Clicking on the links returns a 404 error.
« Reply #3 on: August 24, 2011, 08:33:29 PM »
Are you guys looking at the top of the MAP ROOM for it?  That link is "good" here.  Maybe its another link?
« Reply #4 on: August 24, 2011, 09:17:28 PM »
Yes, the link in question is in the FAQ section under FSDiscover. ;)
archangel1
« Reply #5 on: August 25, 2011, 12:46:19 AM »
The FAQ link gives me a 404 error as well.  However, if I try downloading from the Map Room, I do get a download but the 1Kb zipfile is labelled rtmm.dat which contains a file called rtmm.dat.lnk.  The zipfile I downloaded on Aug.7 is 13Kb, is labelled rtmm and contains a file called rtmm.datSomething ain't kosher.
« Reply #6 on: August 25, 2011, 07:48:25 AM »
Ok, easy solution to this problem.  There will be ONE link that downloads the any file. All other references will point to that link.  Our site has gotten so large that there can easily be multiple links like this. When something like rtmm.dat changes, I have to change the links at all sites ... easy to forget where they might be. So all references to rtmm.dat will refer to the map room where the active link will always reside. I'll get that fixed today.
Update .. ok that one has been fixed.  Look for other multiple links, if you find them, let me know.
« Last Edit: August 25, 2011, 07:56:19 AM by Doug »
