After adding the CRM scenery package when I exit the FSX program it says (not responding) but will not shut down. Any suggestions?
Thanks,
Lazyeight
Sounds like you have made an error in the installation. I suggest that after installing the scenery
AND re-installing the latest ORBX scenery libraries (a must), shut down you computer, restart, use FTX Central and switch to Default, start FSX then shut it down use FTX Central and switch it back to North America. Start FSX fly a bit and then try shutting down. If all works then I would do a disk clean up and defrag the HD. Remember you just mucked about with almost 13 GB of files (4GB download and 9.1GB installed CRM).
Always have to re-install the ORBX libraries
after installing any ORBX North America Scenery
