Author Topic: My favorite panel.cfg on Cesna185f  (Read 4999 times)
addy
« on: May 30, 2011, 02:07:18 PM »
I have chanced the gauges on the panel of my C185f. On the top are the airspeedindicator-, alltitude-, attitude- and vertical velocitygauge. Having these four gauges up I can have a very quick look on difficult landings where airspeed and VIS is important.
Copy and overwrite the text underneath to your tundra-, standard-, or ski- C185  panel.cfg and give it a try!
[Window Titles]
Window00=MiniPanel
Window01=GPS
Window02=Toggle_AP
Window03=Toggle_Manual
Window04=Toggle_Control
Window05=Toggle_ASI
Window06=Toggle_HI
Window07=Toggle_HA
Window08=Toggle_TC
Window09=Toggle_VOR1
Window10=Toggle_ALT
Window11=Toggle_VAR
Window12=Toggle_MAN
Window13=Toggle_RPM
Window14=Toggle_FF
Window15=Toggle_VOR2
Window16=Toggle_MINIPANEL
Window17=INFO
[Window00]
Background_color=0,0,0
size_mm=1050,350
window_size_ratio=1.000
position=0
visible=0
ident=100
window_size= 0.810, 0.360
window_pos= 0.000, 0.640
zorder=15
gauge00=C1855!Airspeed,  2,46,138,138
gauge01=C1855!Vertical Speed,  152,200,127,128
gauge02=C1855!Altimeter,  3,198,136,137
gauge03=C1855!multi,  575,48,232,129
gauge04=C1855!Manifold,  289,198,139,133
gauge05=C1855!RPM Indicator,  436,197,135,138
gauge06=C1855!Fuelflow,  581,200,133,132
gauge07=C1855!Turn Coordinator,  426,44,147,139
gauge08=C1855!Heading Indicator,  150,50,132,145
gauge09=C1855!attitude_indicator,  294,49,128,132
gauge10=C1855!vor1,  818,51,128,131
gauge11=C1855!vor2,  818,200,129,132
gauge12=C1855!EGT,  727,193,75,75
[Window01]
size_mm=545,354
position=0
visible=0
ident=794
window_size= 0.300, 0.220
window_pos= 0.010, 0.455
zorder=0
gauge00=FSGPS295Carenado5!gps_295,  0,0,545,354
gauge01=C1855!Toggle_GPS,  35,69,329,246
[Window02]
size_mm=368,163
position=0
visible=0
ident=790
window_size= 0.220, 0.130
window_pos= 0.745, 0.690
zorder=0
gauge00=C18525!RadioAP2,  0,0,367
gauge01=C1855!Toggle_AP,  333,1,35,35
[Window03]
size_mm=600,600
position=0
visible=0
ident=793
window_size= 0.391, 0.521
window_pos= 0.610, 0.020
zorder=5
gauge00=C185ManualOMS!manualOMS,  0,0,600,600
[Window04]
size_mm=280,188
position=0
visible=0
ident=795
window_size= 0.211, 0.189
window_pos= 0.010, 0.180
zorder=5
gauge00=C1855!Control_window_tun,  0,0,280,188
[Window05]
size_mm=500,500
position=0
visible=0
ident=780
window_size= 0.110, 0.147
window_pos= 0.000, 0.680
zorder=16
gauge00=C1855!Airspeed,  0,0,500,500
[Window06]
size_mm=448,494
position=0
visible=0
ident=785
window_size= 0.110, 0.162
window_pos= 0.110, 0.680
zorder=0
gauge00=C1855!Heading Indicator,  0,0,448,494
[Window07]
size_mm=320,331
position=0
visible=0
ident=781
window_size= 0.110, 0.152
window_pos= 0.224, 0.680
zorder=0
gauge00=C1855!attitude_indicator,  0,0,320,331
[Window08]
size_mm=500,475
position=0
visible=0
ident=784
window_size= 0.122, 0.156
window_pos= 0.330, 0.675
zorder=0
gauge00=C1855!Turn Coordinator,  0,0,500,475
[Window09]
size_mm=433,443
position=0
visible=0
ident=783
window_size= 0.112, 0.150
window_pos= 0.630, 0.680
zorder=0
gauge00=C1855!vor1,  0,0,433,443
[Window10]
size_mm=443,448
position=0
visible=0
ident=782
window_size= 0.110, 0.148
window_pos= 0.000, 0.830
zorder=0
gauge00=C1855!Altimeter,  0,0,443,448
[Window11]
size_mm=445,448
position=0
visible=0
ident=786
window_size= 0.107, 0.142
window_pos= 0.112, 0.831
zorder=0
gauge00=C1855!Vertical Speed,  0,0,445,448
[Window12]
size_mm=500,478
position=0
visible=0
ident=791
window_size= 0.114, 0.144
window_pos= 0.221, 0.830
zorder=0
gauge00=C1855!Manifold,  0,0,500,478
[Window13]
size_mm=402,409
position=0
visible=0
ident=788
window_size= 0.110, 0.149
window_pos= 0.336, 0.828
zorder=0
gauge00=C1855!RPM Indicator,  0,0,402,409
[Window14]
size_mm=456,452
position=0
visible=0
ident=792
window_size= 0.107, 0.143
window_pos= 0.445, 0.831
zorder=0
gauge00=C1855!Fuelflow,  0,0,456,452
[Window15]
size_mm=456,452
position=0
visible=0
ident=787
window_size= 0.112, 0.149
window_pos= 0.630, 0.832
zorder=0
gauge00=C1855!vor2,  0,0,433,443
[Window16]
size_mm=600,335
position=0
visible=0
ident=789
window_size= 0.170, 0.104
window_pos= 0.455, 0.690
zorder=0
gauge00=C1855!multi,  0,0,600,335
[Window17]
size_mm=419,181
position=0
visible=1
ident=142
window_size= 0.290, 0.129
window_pos= 0.010, 0.020
[Vcockpit01]
size_mm=512,512
visible=0
pixel_size=1024,1024
texture=$Panel_C185_1
gauge00=C1855!Turn Coordinator,  5,174,162,157
gauge01=C1855!attitude_indicator,  340,173,164,164
gauge02=C1855!Fuelflow,  339,340,165,165
gauge03=C1855!Vor2,  170,3,168,168
gauge04=C1855!Airspeed,  341,3,167,167
gauge05=C1855!Vertical Speed,  6,340,161,162
gauge06=C1855!RPM Indicator,  4,3,162,166
gauge07=C1855!Altimeter, 176,174,152,158
gauge08=C1855!Heading Indicator,  171,340,162,162
[Vcockpit02]
size_mm=512,512
visible=0
texture=$Panel_C185_2
gauge00=C1855!Clock,  278,11,110,109,4,113,285,117
gauge01=C1855!Radio,  9,196,256,87
gauge02=C1855!Radio2,  8,9,262,107
gauge03=C1855!Vor1,  279,362,148,147
gauge04=C1855!compass,  400,125,107,68
gauge05=C1855!temp,  279,126,117,117
gauge06=C1855!Manifold,  279,246,119,113
gauge07=C1855!multi,  8,287,235,131
gauge08=C1855!EGT,  391,10,108,110
gauge09=C1855!transponder,  9,121,256,68
gauge10=C1855!AOM,  8,421,266,70
gauge11=C1855!Ignition Switch,  433,468,40,40
[Vcockpit03]
size_mm=512,512
visible=0
texture=$Panel_C185_3
gauge00=C18525!RadioAP2,  7,6,484
gauge01=C1855!adf,  5,225,442,183
gauge02=C1855!Toggle_AP,  368,6,121,104
gauge03=C1855!Toggle_GPS2,  332,417,163,89
gauge04=C1855!Toggle_Manual,  26,423,294,68
[Vcockpit04]
size_mm=512,512
visible=0
texture=$Panel_C185_4
gauge00=FSGPS295Carenado5!gps_295,  17,77,479,311
gauge01=C1855!Toggle_GPS,  46,138,294,211
[Color]
Day=255,255,255
Night=128,64,64
Luminous=128,64,64
[Default View]
X=0
Y=0
SIZE_X=8191
Re: My favorite panel.cfg on Cesna185f
« Reply #1 on: May 30, 2011, 04:22:11 PM »
Addy,
a screen shot of the results of your mods would help induce folks to try it quicker if they knew what it looks like first.  Could you add a screenie to the post?
addy
« Reply #2 on: May 30, 2011, 04:41:00 PM »
You are right:
Gypsy Pilot
« Reply #3 on: May 31, 2011, 01:33:50 PM »
I know that I an old and thick headed but please tell me what key combinations you use to view windows 09 and up.
~~ Dale ~~
Dale "Gypsy Pilot" Evans
Fly like a Float Plane Pilot
Disconnect those brakes
« Reply #4 on: May 31, 2011, 05:10:20 PM »
Dale,
unless I'm mistaken those windows are what comes up with the SHFT1 key press.  All the gauges superimposed on the monitor, when you are in the 2D cockpit which does not have a panel.
« Reply #5 on: June 02, 2011, 01:56:38 AM »
Dale,
     You can access those windows by clicking on the menu bar "view", click on "instruments", then choose the window you want from the dropdown list.
« Last Edit: June 02, 2011, 08:14:09 AM by jeff3163 »
