Author Topic: CIRP Hovercraft  (Read 2178 times)
Garry
CIRP Hovercraft
« on: June 01, 2019, 10:26:26 AM »
Hello
Can I ask for some clarification, please:
There is no virtual cockpit [like in the aircraft] nor any internal views such as 'looking backwards' at passengers.
The driving views are either:
  • outside with a panel overlay, or
    inside looking forward with a panel overlay
The hovercraft does look good from the outside all lit up but is there any way to boost the forward lighting?
All I see are two white dots [nav lights?]- see pic [I do not have 3d redux lighting] which are so ineffectual it makes driving at night impossible.
Thank you
Josh
Re: CIRP Hovercraft
« Reply #1 on: June 01, 2019, 11:00:39 PM »
     You are correct.  Those VC views are broken.  They did work, but don't now.   :'(  It would be nice if Rod or someone could fix that.  Maybe someday.  :P
I recommend the shockwave 3D redux lights.   ;)
(Why are you running around in the woods at night anyway?   :o  ;D )
« Last Edit: June 01, 2019, 11:08:29 PM by jeff3163 »
Garry
Re: CIRP Hovercraft
« Reply #2 on: June 02, 2019, 08:15:19 PM »
Jeff - nothing sinister I assure you!! ;)
In my defence I quote from the Hovercraft pdf:
"The object is fully “lit up” for night operations. Flashing strobes and REDUX lighting if you
have it. Being out on the ice at night is a lot of fun."
And I checked an old friend who has the redux app [v2a I think] to see if it would work in my P3D.
Seems I need FSX and no matter what we try we can't trick it into installing into P3D. :( :'(
Regards
Josh
Re: CIRP Hovercraft
« Reply #3 on: June 03, 2019, 08:13:52 AM »
I'm not sure if I "installed" to P3D.  Most likely that I copied the files from FSX to P3D.  I have the shockwave lights in my effects folder, and they work.   ;)  (... also Shockwave_Lights.cab in the gauges folder).   :P
« Last Edit: June 03, 2019, 08:20:00 AM by jeff3163 »
Garry
Re: CIRP Hovercraft
« Reply #4 on: June 03, 2019, 11:01:49 AM »
Hmmm - I might have to install FSX and copy the files across..from what I've seen it will be worth the effort.
