Author Topic: Groundhandling v6.0  (Read 5448 times)
Groundhandling v6.0
« on: May 31, 2019, 08:02:42 AM »
There is an updated (late 2017) - Groundhandling v6.0 which has updated code definitions for P3Dv4 and also contains the newer XMLsound files used in P3Dv4x). (But still contains updated files that still support  FSX/P3Dv2/3).
Groundhandling V6.0 Links:
(Perfect flight) - http://www.perfectflight.cloud/2017/12/03/fsxp3d-groundhandling-v-6-0/
(AVSIM): https://library.avsim.net/esearch.php?DLID=202116&CatID=p3dgau
(Simouthouse): http://www.sim-outhouse.com/sohforums/local_links.php?catid=218&linkid=23145
Note: Groundhandling 6 gauge requires the installation of Microsoft "Visual C++ 2015 Redistributable:
Link: https://www.microsoft.com/en-us/download/details.aspx?id=48145)
Groundhandling window definitions have to be added to each aircraft's panel.cfg file that you want the groundhandling to be available: these entries/format are all contained in the Groundhandling 6
README GroundhandlingV6.txt file: It contains a full readme: the install, notes and all the definitions (copy/paste) and how to - for the panel.cfg.
PS: (But make sure you leave RCB_Groundhandling5.CAB files in your gauges as it was used in the CIRP  tricked out Stalwart). (There is no conflict between Groundhandling v5.0 and Groundhandling v6.0).
« Last Edit: May 31, 2019, 08:06:57 AM by nbrich1 »
Garry
Re: Groundhandling v6.0
« Reply #1 on: July 12, 2019, 12:12:10 PM »
Hi Norm
I have installed:
Visual C++ 2015 Redistributable (x86) 14.0.23026
Visual C++ 2015 Redistributable (x86) 14.0.24215
Visual C++ 2017 Redistributable (x64) 14.14.26429
I cannot download the 2015 (x64) version as the MS page tells me the newer version is installed.
Will it still work?
« Reply #2 on: July 12, 2019, 01:38:18 PM »
Yep it should work.. read the docs and have to set it up in whatever planes you want it to be usable but yes should work just fine.
Garry
« Reply #3 on: July 15, 2019, 10:27:41 AM »
Thanks, Norm
