Home (FSX/P3D)
Home (MSFS2020)
Scenery
Navigation
Enhancements
Activities
Welcome,
Guest
. Please
login
or
register
April 25, 2024, 04:01:18 AM
Home
Help
Login
Register
Misty Moorings Forums
General Discussion
Zoom factor
« previous
next »
Print
Pages: [
1
Author
Topic: Zoom factor (Read 2927 times)
Hero Member
Zoom factor
on:
April 14, 2019, 07:23:32 PM »
Which zoom settings are you using?
Yesterday I made the following test: From my house (just some 15 miles east of LOWI) I selected two mountain peaks in the distance. Then I used a glass plate and held it in front of my face at the same distance my monitor is away from my eyes.
I marked the two mountain peaks on the glass plate and measured the distance.
Back at my rig I placed my aircraft at the exact GPS coordinates facing the two mountain peaks. Then I adjusted the zoom so the distance of the two peaks on the monitor was the same as on the glass plate.
I ended up with a zoom of 0.65 (Widscreen aspect checked). If this zoom works depends on the aircraft cockpit and how much I can shift the eyepoint back.
Logged
Misty Moorings Team
Hero Member
Re: Zoom factor
Reply #1 on:
April 14, 2019, 07:40:47 PM »
Hey Karl,
Innsbruck is a beautiful place to live. You are lucky to be surrounded by such beauty. In FSX/P3D the aspect ratios and geographcal relationships are not an exact match to real life for various reasons. That said they are pretty close. However, when viewing things at distance a small error can add up.
The problem with the widescreen setting is that if you use a zoom factor that is below 1.0 (which might help correct something at distance in the center of your view) additional distortion is added to your display the farther you are from the very center of the screen.
I always fly at 1.0 to minimize that distortion since I use a three screen system and with the widescreen setting turned on. You have to choose between a slight scaling variance at long distance as opposed to significant distortion as you reach the edges of the display screen.
At least that is my take on it....
Logged
Hero Member
Re: Zoom factor
Reply #2 on:
April 14, 2019, 07:53:09 PM »
Well, I use just one monitor, on 3 monitors it is probably different.
Logged
Hero Member
Re: Zoom factor
Reply #3 on:
April 14, 2019, 08:10:14 PM »
And I never had the chance to test a multi monitor setup, must be a great experience!
Logged
Misty Moorings Team
Hero Member
Re: Zoom factor
Reply #4 on:
April 14, 2019, 08:31:08 PM »
Yep, I thought you might be using 3 monitors. It is pretty cool using 3 monitors! I run at 5040 X 1050 resolution. You are right, about multi monitor being different than single monitor.
Logged
Misty Moorings Team
Hero Member
Misty Flying Club VA, Sim Troubleshooting & Help
Re: Zoom factor
Reply #5 on:
April 15, 2019, 05:19:19 PM »
Just BLEW one of My GPU.. Dead dead dead.. Well it powers up and fans spin but Dead Dead Dead as there is no display output. (I run two GPU and each runs 3 monitors.. well not right now mind you!! lol.. The PC is on the bench all ripped apart.. (I have to make room to fit a bigger GPU in as a new primary GPU!!)
Hopefully won't take me too long to get up and running but the pocket book is going to hurt!!.
PS. Run at 100.0 in VC. If in cockpit view run .70 but almost run in vc view.
Last Edit: April 16, 2019, 08:23:44 AM by nbrich1
Logged
Misty Moorings Team
Hero Member
Legacy RTMM Library Manager
Re: Zoom factor
Reply #6 on:
April 15, 2019, 05:50:52 PM »
kaha,
If you want a true 1:1 perspective, you need to play with your monitor resolution settings until you find the sweet spot. Otherwise accept the fact that a simulator doesn't, and can't, reflect real life.
Logged
Hero Member
Re: Zoom factor
Reply #7 on:
April 15, 2019, 06:03:24 PM »
Quote from: nbrich1 on April 15, 2019, 05:19:19 PM
OMG... worst scenario. How old is the GPU? No warranty anymore?
Logged
Hero Member
Re: Zoom factor
Reply #8 on:
April 15, 2019, 06:05:58 PM »
Quote from: ualani on April 15, 2019, 05:50:52 PM
...play with your monitor resolution settings ...
I run a 40" 4K monitor. So what would be the possibilities to play with the resolution?
Logged
Hero Member
Re: Zoom factor
Reply #9 on:
April 15, 2019, 06:08:25 PM »
Ahh, you mean resolution in respect to monitor size?
Logged
Misty Moorings Team
Hero Member
Re: Zoom factor
Reply #10 on:
April 15, 2019, 07:12:00 PM »
I don't know how else to say it: what is your display resolution? Just to throw out theoretical numbers, is it 1440 x 900, 1336 x 768? Look at your video card's control panel. I have an Nvidia video card and there's an Nvidia control panel that has all kinds of display options that can be tweaked.
Logged
Misty Moorings Team
Hero Member
Watercraft-Panels-Paint
Re: Zoom factor
Reply #11 on:
April 15, 2019, 08:57:45 PM »
I have three 42" monitors.
I've never expected them to match "real life" though. Just an approximation. My resolution is 5760x1080p on a 1080Ti.
Logged
Win10Pro64, MSFS 1.25.9.0, P3Dv4.3.29.25520, AMD Ryzen7 1800X@3.6 GHz , 32Gb RAM, GTX 1080 Ti, 2x42" Vizio Monitors, HTC Vive VR HMD, Saitek Yoke/Pedals/trim wheel, XBox360 Controller, G27 steering wheel w/shifter+pedals.
Misty Moorings Team
Hero Member
Re: Zoom factor
Reply #12 on:
April 15, 2019, 09:04:22 PM »
It was my weaker and oldest gpu that blew up (my secondary)... a 6 yr old- GeForce GTX 650 TI Boost which is now a wee boat anchor.. no warranty now but it served well for it's lifetime.
PS Karl.. might want to use the native resolution for that 4k but as Steve says your going control panel should have options for different resolutions .. that is depending on your actual GPU and it's power/strength.
As always the higher you run the resolution the more the strain on the system. But if you have the CPU and GPU..power.. give higher resolutions a try...lol..
Last Edit: April 16, 2019, 08:26:52 AM by nbrich1
Logged
Print
Pages: [
1
« previous
next »
General Discussion
Zoom factor
