Author Topic: Misty Cruise Ship Not Showing  (Read 3955 times)
Garry
« on: March 30, 2019, 01:08:10 PM »
Hi RTMMers
For the life of me I cannot get the Misty Cruise Ship and the 2 fishing vessels to appear in Ketchikan Harbour.
I've tried the recommended install method [root\add on scenery\scenery + root\ scenery\world\scenery] and the xml method in Lorby inserting scenery at layer 509 in my library and the scenery\world\scenery at layer 3 in the same xml. I overwrote the contents of the aircraft.cfg file in the fishing vessel.
I've checked the library object tester and the Tongass house with the totems shows [although for some reason the orange smoke is suddenly not showing, just some small object that looks like a sprinkler instead] so I'm assuming Tongass Fjords is installed ok.
Near PAKT airport (orbx V115) I can see the ship in dry dock with the 3 commercial ships outside and towards the east end of the harbour I can see 3 cruise ships, none of which looks like the black cruise ship in the screenshot, they are white.  My ship slider is at 100%.
FWIW the position of these cruise ships changes depending on whether ORBX PAKT is installed or not.
I am assuming the misty cruise ship appears somewhere near the airport, where all the yachts are moored.
Does anyone have any ideas?
Re: Misty Cruise Ship Not Showing
« Reply #1 on: March 31, 2019, 02:38:04 PM »
Since I don't use the Lorby app, I have no idea what you are talking about.  The vessels exist in the P3dv4\Sim Objects folder and the traffic files in the P3Dv4\Scenery\World Scenery folder.  I don't understand the part about overwriting the vessel's aircraft config folder.
« Last Edit: March 31, 2019, 07:23:30 PM by dexthom »
Garry
« Reply #2 on: May 01, 2019, 05:29:39 AM »
Thanks Dexter.
All sorted now.
Garry
« Reply #3 on: May 11, 2019, 06:48:19 AM »
Hi Dexter
From the readme file:
"Move the file aircraft.cfg to FSX\SimObjects\Boats\AI_Vessel_TF_Fishing_Boat_FSX and overwrite the existing aircraft.cfg for this AI Boat."
Cheers
Josh
