Author Topic: Stewart OPs center for CIRP - objects below ground level  (Read 2260 times)
« on: March 29, 2019, 08:37:18 AM »
After installing CIRP already a while ago I installed the Stewart OPs center today. There is a problem with the objects sinking into the ground. Is there a fix?
Thx,
Re: Stewart OPs center for CIRP - objects below ground level
« Reply #1 on: March 29, 2019, 08:57:27 AM »
Is your mesh set to 5m? Are you using a 3rd party mesh?
« Reply #2 on: March 29, 2019, 09:40:38 AM »
Yes, 5m and no 3rd party mesh (got rid of that OFX USA 5m mesh 'cause it messed up other things). Just ORBX including payware CZST. I'm on P3D V4.4.
« Reply #3 on: March 29, 2019, 04:14:56 PM »
I believe this enhancement that I did was made for use with the payware Stewart airport by ORBX. It's been awhile since I've used it to be 100% sure but that would be my first recommendation.
« Reply #4 on: March 29, 2019, 04:31:37 PM »
Yes, I have the payware ORBX Stewart installed.
« Reply #5 on: March 30, 2019, 01:35:20 PM »
Hmmmm.....
At the top of the readme_install_crip_ops_base 2.txt file for the scenery it says:
NAME
CIRP Operations Base (Version 2.0)
Compatible with ORBX/FTX CZST Airport
But in Installation section it says:
INSTALLATION
IMPORTANT:
This scenery is for the DEFAULT FSX/P3D Stewart Airport, not the UPDATED version from ORBX.
So, OPs picture tends to make me want to believe the Installtion section but Doug or Brad will need to clarify this confict in the readme_install.....txt file.
