Author Topic: CTD Before Loading  (Read 4358 times)
John
CTD Before Loading
« on: March 26, 2019, 12:08:23 AM »
Hi all, my FSXse will not load a FP before CTD.  I'm getting 2 error msgs: 1. sim1.dll 2. terrain.dll  :(  Help please  ::)
John
« Last Edit: March 26, 2019, 12:58:11 AM by John »
Re: CTD Before Loading
« Reply #1 on: March 26, 2019, 08:53:12 PM »
Hi if i remember : if you have a save flight , you need to delete , and normaly your FSX work ..
but some experts here may be help you for an other way , better than me .. !
John
« Reply #2 on: March 28, 2019, 03:11:44 PM »
I may have a couple corrupt dll files.  Anyone know where to get good clean sim1.dll and texture.dll?
John
« Reply #3 on: March 28, 2019, 06:27:06 PM »
 8) Let Steam verify the files. If they are corrupt, it will replace them.
John
« Reply #4 on: March 29, 2019, 02:43:25 AM »
Thank you Sue, I'll check into that  :-[
Update: Well, Steam replaced my files but that didn't help.  Loads to about 84% then CTD >:(
John
« Last Edit: March 30, 2019, 02:16:52 AM by John »
« Reply #5 on: March 30, 2019, 01:06:11 PM »
A little confused on your problem.   Your initial post said ...."Hi all, my FSXse will not load a FP before CTD".
Not sure what FP meant.   I took it to mean a flight plan.  Maybe you meant something else.  Your last post says you get t0 84% and then CTD.   Do you know what module is faulting at that point?  Can you post the full faulting message?  What platform are you running on?
John
« Reply #6 on: March 30, 2019, 04:34:40 PM »
Hi Rod, flight plan is right.  Running Win7/64.  Two modules: sim1.dll and texture.dll.  This may take a lot of room ::)
Version=1
EventType=APPCRASH
EventTime=131983985033340786
ReportType=2
Consent=1
ReportIdentifier=6d7cbdaf-52af-11e9-8d20-4061865cd292
IntegratorReportIdentifier=6d7cbdae-52af-11e9-8d20-4061865cd292
WOW64=1
Response.type=4
Sig[0].Name=Application Name
Sig[0].Value=fsx.exe
Sig[1].Name=Application Version
Sig[1].Value=10.0.62615.0
Sig[2].Name=Application Timestamp
Sig[2].Value=559f9a9a
Sig[3].Name=Fault Module Name
Sig[3].Value=sim1.dll
Sig[4].Name=Fault Module Version
Sig[4].Value=10.0.62615.0
Sig[5].Name=Fault Module Timestamp
Sig[5].Value=559f9ab4
Sig[6].Name=Exception Code
Sig[6].Value=c0000005
Sig[7].Name=Exception Offset
Sig[7].Value=000a9bfe
DynamicSig[1].Name=OS Version
DynamicSig[1].Value=6.1.7601.2.1.0.768.3
DynamicSig[2].Name=Locale ID
DynamicSig[2].Value=1033
DynamicSig[22].Name=Additional Information 1
DynamicSig[22].Value=9e27
DynamicSig[23].Name=Additional Information 2
DynamicSig[23].Value=9e2778096e7e1e2a2e0302fe58f3eea8
DynamicSig[24].Name=Additional Information 3
DynamicSig[24].Value=9e27
DynamicSig[25].Name=Additional Information 4
DynamicSig[25].Value=9e2778096e7e1e2a2e0302fe58f3eea8
UI[2]=C:\Program Files (x86)\Steam\steamapps\common\FSX\fsx.exe
UI[3]=Microsoft Flight Simulator® has stopped working
UI[4]=Windows can check online for a solution to the problem.
UI[5]=Check online for a solution and close the program
UI[6]=Check online for a solution later and close the program
UI[7]=Close the program
LoadedModule[0]=C:\Program Files (x86)\Steam\steamapps\common\FSX\fsx.exe
LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
LoadedModule[2]=C:\Windows\syswow64\kernel32.dll
LoadedModule[3]=C:\Windows\syswow64\KERNELBASE.dll
LoadedModule[4]=C:\Windows\WinSxS\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_cbf5e994470a1a8f\MFC80.DLL
LoadedModule[5]=C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\MSVCR80.dll
LoadedModule[6]=C:\Windows\syswow64\msvcrt.dll
LoadedModule[7]=C:\Windows\syswow64\GDI32.dll
LoadedModule[8]=C:\Windows\syswow64\USER32.dll
LoadedModule[9]=C:\Windows\syswow64\ADVAPI32.dll
LoadedModule[10]=C:\Windows\SysWOW64\sechost.dll
LoadedModule[11]=C:\Windows\syswow64\RPCRT4.dll
LoadedModule[12]=C:\Windows\syswow64\SspiCli.dll
LoadedModule[13]=C:\Windows\syswow64\CRYPTBASE.dll
LoadedModule[14]=C:\Windows\syswow64\LPK.dll
LoadedModule[15]=C:\Windows\syswow64\USP10.dll
LoadedModule[16]=C:\Windows\syswow64\SHLWAPI.dll
LoadedModule[17]=C:\Windows\WinSxS\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.6195_none_d09154e044272b9a\MSVCP80.dll
LoadedModule[18]=C:\Program Files (x86)\Steam\steamapps\common\FSX\steam_api.dll
LoadedModule[19]=C:\Windows\syswow64\SHELL32.dll
LoadedModule[20]=C:\Windows\syswow64\ole32.dll
LoadedModule[21]=C:\Windows\system32\apphelp.dll
LoadedModule[22]=C:\Windows\AppPatch\AcGenral.DLL
LoadedModule[23]=C:\Windows\system32\UxTheme.dll
LoadedModule[24]=C:\Windows\system32\WINMM.dll
LoadedModule[25]=C:\Windows\system32\samcli.dll
LoadedModule[26]=C:\Windows\syswow64\OLEAUT32.dll
LoadedModule[27]=C:\Windows\system32\MSACM32.dll
LoadedModule[28]=C:\Windows\system32\VERSION.dll
LoadedModule[29]=C:\Windows\system32\sfc.dll
LoadedModule[30]=C:\Windows\system32\sfc_os.DLL
LoadedModule[31]=C:\Windows\syswow64\USERENV.dll
LoadedModule[32]=C:\Windows\syswow64\profapi.dll
LoadedModule[33]=C:\Windows\system32\dwmapi.dll
LoadedModule[34]=C:\Windows\syswow64\SETUPAPI.dll
LoadedModule[35]=C:\Windows\syswow64\CFGMGR32.dll
LoadedModule[36]=C:\Windows\syswow64\DEVOBJ.dll
LoadedModule[37]=C:\Windows\syswow64\urlmon.dll
LoadedModule[38]=C:\Windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
LoadedModule[39]=C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
LoadedModule[40]=C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
LoadedModule[41]=C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
LoadedModule[42]=C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
LoadedModule[43]=C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
LoadedModule[44]=C:\Windows\syswow64\normaliz.DLL
LoadedModule[45]=C:\Windows\syswow64\iertutil.dll
LoadedModule[46]=C:\Windows\syswow64\WININET.dll
LoadedModule[47]=C:\Windows\system32\MPR.dll
LoadedModule[48]=C:\Windows\AppPatch\AcLayers.DLL
LoadedModule[49]=C:\Windows\system32\WINSPOOL.DRV
LoadedModule[50]=C:\Windows\AppPatch\AcSpecfc.DLL
LoadedModule[51]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.7601.18837_none_ec86b8d6858ec0bc\COMCTL32.dll
LoadedModule[52]=C:\Windows\system32\mscms.dll
LoadedModule[53]=C:\Windows\system32\DDRAW.dll
LoadedModule[54]=C:\Windows\system32\DCIMAN32.dll
LoadedModule[55]=C:\Windows\syswow64\COMDLG32.dll
LoadedModule[56]=C:\Windows\syswow64\IMM32.dll
LoadedModule[57]=C:\Windows\syswow64\MSCTF.dll
LoadedModule[58]=C:\Windows\syswow64\WS2_32.dll
LoadedModule[59]=C:\Windows\syswow64\NSI.dll
LoadedModule[60]=C:\Windows\system32\msi.dll
LoadedModule[61]=C:\Windows\WinSxS\x86_microsoft.vc80.mfcloc_1fc8b3b9a1e18e3b_8.0.50727.6195_none_03ce2c72205943d3\MFC80ENU.DLL
LoadedModule[62]=C:\Program Files (x86)\Steam\gameoverlayrenderer.dll
LoadedModule[63]=C:\Windows\syswow64\PSAPI.DLL
LoadedModule[64]=C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
LoadedModule[65]=C:\Program Files (x86)\Steam\steamapps\common\FSX\language.dll
LoadedModule[66]=C:\Program Files (x86)\Steam\steamclient.dll
LoadedModule[67]=C:\Windows\syswow64\CRYPT32.dll
LoadedModule[68]=C:\Windows\syswow64\MSASN1.dll
LoadedModule[69]=C:\Windows\system32\IPHLPAPI.DLL
LoadedModule[70]=C:\Windows\system32\WINNSI.DLL
LoadedModule[71]=C:\Windows\syswow64\imagehlp.dll
LoadedModule[72]=C:\Program Files (x86)\Steam\tier0_s.dll
LoadedModule[73]=C:\Program Files (x86)\Steam\vstdlib_s.dll
LoadedModule[74]=C:\Windows\system32\MSWSOCK.dll
LoadedModule[75]=C:\Windows\system32\Secur32.dll
LoadedModule[76]=C:\Windows\System32\wshtcpip.dll
LoadedModule[77]=C:\Program Files (x86)\Steam\steam.dll
LoadedModule[78]=C:\Program Files (x86)\Steam\Steam2.dll
LoadedModule[79]=C:\Windows\system32\NLAapi.dll
LoadedModule[80]=C:\Windows\system32\napinsp.dll
LoadedModule[81]=C:\Windows\system32\pnrpnsp.dll
LoadedModule[82]=C:\Windows\system32\DNSAPI.dll
LoadedModule[83]=C:\Windows\System32\winrnr.dll
LoadedModule[84]=C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
LoadedModule[85]=C:\Windows\System32\fwpuclnt.dll
LoadedModule[86]=C:\Windows\system32\rasadhlp.dll
LoadedModule[87]=C:\Program Files (x86)\Steam\DbgHelp.dll
LoadedModule[88]=C:\Program Files (x86)\Steam\CSERHelper.dll
LoadedModule[89]=C:\Program Files (x86)\Steam\steamapps\common\FSX\API.DLL
LoadedModule[90]=C:\Program Files (x86)\Steam\steamapps\common\FSX\ablscpt.dll
LoadedModule[91]=C:\Program Files (x86)\Steam\steamapps\common\FSX\flight.dll
LoadedModule[92]=C:\Program Files (x86)\Steam\steamapps\common\FSX\ai_player.dll
LoadedModule[93]=C:\Program Files (x86)\Steam\steamapps\common\FSX\acontain.dll
LoadedModule[94]=C:\Program Files (x86)\Steam\steamapps\common\FSX\controls.dll
LoadedModule[95]=C:\Windows\system32\DINPUT8.dll
LoadedModule[96]=C:\Program Files (x86)\Steam\steamapps\common\FSX\fsui.dll
LoadedModule[97]=C:\Program Files (x86)\Steam\steamapps\common\FSX\atc.dll
LoadedModule[98]=C:\Program Files (x86)\Steam\steamapps\common\FSX\facilities.dll
LoadedModule[99]=C:\Program Files (x86)\Steam\steamapps\common\FSX\demo.dll
LoadedModule[100]=C:\Program Files (x86)\Steam\steamapps\common\FSX\main.dll
LoadedModule[101]=C:\Program Files (x86)\Steam\steamapps\common\FSX\fe.dll
LoadedModule[102]=C:\Program Files (x86)\Steam\steamapps\common\FSX\util.dll
LoadedModule[103]=C:\Program Files (x86)\Steam\steamapps\common\FSX\simprop.dll
LoadedModule[104]=C:\Program Files (x86)\Steam\steamapps\common\FSX\g2d.dll
LoadedModule[105]=C:\Windows\system32\d3dx9_34.dll
LoadedModule[106]=C:\Windows\system32\d3dx10_34.dll
LoadedModule[107]=C:\Windows\system32\d3d9.dll
LoadedModule[108]=C:\Windows\system32\d3d8thk.dll
LoadedModule[109]=C:\Program Files (x86)\Steam\steamapps\common\FSX\g3d.dll
LoadedModule[110]=C:\Program Files (x86)\Steam\steamapps\common\FSX\panels.dll
LoadedModule[111]=C:\Program Files (x86)\Steam\steamapps\common\FSX\multiplayer.dll
LoadedModule[112]=C:\Program Files (x86)\Steam\steamapps\common\FSX\sdkencryptedappticket.dll
LoadedModule[113]=C:\Program Files (x86)\Steam\steamapps\common\FSX\ui.dll
LoadedModule[114]=C:\Program Files (x86)\Steam\steamapps\common\FSX\sound.dll
LoadedModule[115]=C:\Program Files (x86)\Steam\steamapps\common\FSX\sim1.dll
LoadedModule[116]=C:\Program Files (x86)\Steam\steamapps\common\FSX\simscheduler.dll
LoadedModule[117]=C:\Program Files (x86)\Steam\steamapps\common\FSX\visualfx.dll
LoadedModule[118]=C:\Program Files (x86)\Steam\steamapps\common\FSX\window.dll
LoadedModule[119]=C:\Program Files (x86)\Steam\steamapps\common\FSX\terrain.dll
LoadedModule[120]=C:\Program Files (x86)\Steam\steamapps\common\FSX\weather.dll
LoadedModule[121]=C:\Windows\system32\DSOUND.dll
LoadedModule[122]=C:\Windows\system32\POWRPROF.dll
LoadedModule[123]=C:\Program Files (x86)\Steam\steamapps\common\FSX\symmap.dll
LoadedModule[124]=C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24385_none_5c0ad4dfa00a8e0a\gdiplus.dll
LoadedModule[125]=C:\Windows\system32\MSIMG32.dll
LoadedModule[126]=C:\Program Files (x86)\Steam\steamapps\common\FSX\xuipc.dll
LoadedModule[127]=C:\Program Files (x86)\Steam\steamapps\common\FSX\livingwater.dll
LoadedModule[128]=C:\Program Files (x86)\Steam\steamapps\common\FSX\fs-traffic.dll
LoadedModule[129]=C:\Program Files (x86)\Steam\steamapps\common\FSX\gps.dll
LoadedModule[130]=C:\Windows\system32\SHFOLDER.dll
LoadedModule[131]=C:\Windows\system32\CRYPTSP.dll
LoadedModule[132]=C:\Windows\system32\rsaenh.dll
LoadedModule[133]=C:\Windows\WinSxS\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9876.0_none_b7e610287b2b4ea5\MSXML4.DLL
LoadedModule[134]=C:\Windows\system32\dxgi.dll
LoadedModule[135]=C:\Windows\system32\d3d11.dll
LoadedModule[136]=C:\Windows\syswow64\WINTRUST.dll
LoadedModule[137]=C:\Windows\system32\nvd3dum.dll
LoadedModule[138]=C:\Windows\system32\bcrypt.dll
LoadedModule[139]=C:\Windows\system32\D3DCompiler_34.dll
LoadedModule[140]=C:\Windows\SysWOW64\bcryptprimitives.dll
LoadedModule[141]=C:\Windows\system32\WindowsCodecs.dll
LoadedModule[142]=C:\Windows\system32\d3d10_1.dll
LoadedModule[143]=C:\Windows\system32\d3d10_1core.dll
LoadedModule[144]=C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPI.dll
LoadedModule[145]=C:\Windows\syswow64\CLBCatQ.DLL
LoadedModule[146]=C:\Windows\SysWOW64\dxdiagn.dll
LoadedModule[147]=C:\Windows\SysWOW64\d3d10.dll
LoadedModule[148]=C:\Windows\SysWOW64\d3d10core.dll
LoadedModule[149]=C:\Windows\system32\wbem\wbemprox.dll
LoadedModule[150]=C:\Windows\system32\wbemcomn.dll
LoadedModule[151]=C:\Windows\system32\RpcRtRemote.dll
LoadedModule[152]=C:\Windows\system32\wbem\wbemsvc.dll
LoadedModule[153]=C:\Windows\system32\wbem\fastprox.dll
LoadedModule[154]=C:\Windows\system32\NTDSAPI.dll
LoadedModule[155]=C:\Windows\system32\winbrand.dll
LoadedModule[156]=C:\Windows\system32\nvapi.dll
LoadedModule[157]=C:\Windows\system32\WTSAPI32.DLL
LoadedModule[158]=C:\Windows\system32\WINSTA.dll
LoadedModule[159]=C:\Windows\SysWOW64\gameux.dll
LoadedModule[160]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24380_none_2b2053e245779417\COMCTL32.dll
LoadedModule[161]=C:\Windows\SysWOW64\XmlLite.dll
LoadedModule[162]=C:\Windows\SysWOW64\wer.dll
LoadedModule[163]=C:\Windows\System32\Wpc.dll
LoadedModule[164]=C:\Windows\System32\wevtapi.dll
LoadedModule[165]=C:\Windows\System32\msxml6.dll
LoadedModule[166]=C:\Windows\system32\SAMLIB.dll
LoadedModule[167]=C:\Windows\system32\netutils.dll
LoadedModule[168]=C:\Program Files (x86)\Steam\steamapps\common\FSX\uiautomationcore.dll
LoadedModule[169]=C:\Windows\system32\OLEACC.dll
LoadedModule[170]=C:\Windows\System32\MMDevApi.dll
LoadedModule[171]=C:\Windows\System32\PROPSYS.dll
LoadedModule[172]=C:\Windows\system32\AUDIOSES.DLL
LoadedModule[173]=C:\Windows\system32\RICHED20.DLL
LoadedModule[174]=C:\Windows\system32\HID.DLL
LoadedModule[175]=C:\Windows\system32\XInput9_1_0.dll
LoadedModule[176]=C:\Windows\system32\wdmaud.drv
LoadedModule[177]=C:\Windows\system32\ksuser.dll
LoadedModule[178]=C:\Windows\system32\AVRT.dll
LoadedModule[179]=C:\Windows\system32\msacm32.drv
LoadedModule[180]=C:\Windows\system32\midimap.dll
LoadedModule[181]=C:\Windows\system32\dinput.DLL
LoadedModule[182]=C:\Windows\System32\wship6.dll
LoadedModule[183]=C:\Program Files (x86)\Steam\steamapps\common\FSX\ORBX\FTX_AU\FTXAA_ORBXLIBS\Scenery\ObjectFlow.dll
LoadedModule[184]=C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
LoadedModule[185]=C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
LoadedModule[186]=C:\Windows\System32\netprofm.dll
LoadedModule[187]=C:\Windows\system32\dhcpcsvc6.DLL
LoadedModule[188]=C:\Windows\System32\npmproxy.dll
LoadedModule[189]=C:\Windows\system32\dhcpcsvc.DLL
LoadedModule[190]=C:\Windows\system32\msiltcfg.dll
LoadedModule[191]=C:\Windows\system32\credssp.dll
LoadedModule[192]=C:\Windows\SysWOW64\schannel.dll
LoadedModule[193]=C:\Windows\system32\ncrypt.dll
LoadedModule[194]=C:\Windows\system32\GPAPI.dll
LoadedModule[195]=C:\Windows\system32\cryptnet.dll
LoadedModule[196]=C:\Windows\syswow64\WLDAP32.dll
LoadedModule[197]=C:\Windows\system32\SensApi.dll
LoadedModule[198]=C:\Windows\system32\WINHTTP.dll
LoadedModule[199]=C:\Windows\system32\webio.dll
LoadedModule[200]=C:\Program Files (x86)\Steam\steamapps\common\FSX\XMLTools.dll
LoadedModule[201]=C:\Windows\WinSxS\x86_microsoft.flightsimulator.simconnect_67c7c14424d61b5b_10.0.61259.0_none_55f5ecdc14f60568\SimConnect.dll
LoadedModule[202]=C:\Windows\system32\MSVCP100.dll
LoadedModule[203]=C:\Windows\system32\MSVCR100.dll
LoadedModule[204]=C:\Program Files (x86)\Steam\steamapps\common\FSX\Modules\FSUIPC4.dll
LoadedModule[205]=C:\Windows\WinSxS\x86_microsoft.flightsimulator.simconnect_1ed9da73c880e429_10.0.62615.0_none_69960aa860d87067\SimConnect.dll
LoadedModule[206]=C:\Program Files (x86)\Steam\steamapps\common\FSX\as_srv\as_btstrp.dll
LoadedModule[207]=C:\Windows\system32\msadp32.acm
LoadedModule[208]=C:\Windows\SysWOW64\ieframe.dll
LoadedModule[209]=C:\Windows\SysWOW64\api-ms-win-downlevel-shell32-l1-1-0.dll
LoadedModule[210]=C:\Windows\system32\ntmarta.dll
LoadedModule[211]=C:\Windows\SysWOW64\mshtml.dll
LoadedModule[212]=C:\Windows\system32\msimtf.dll
LoadedModule[213]=C:\Windows\system32\msls31.dll
LoadedModule[214]=C:\Windows\system32\d2d1.dll
LoadedModule[215]=C:\Windows\system32\DWrite.dll
LoadedModule[216]=C:\Windows\system32\D3D10Warp.dll
LoadedModule[217]=C:\Windows\system32\MLANG.dll
LoadedModule[218]=C:\Windows\system32\SXS.DLL
LoadedModule[219]=C:\Windows\SysWOW64\jscript9.dll
LoadedModule[220]=C:\Program Files (x86)\Common Files\microsoft shared\ink\tiptsf.dll
LoadedModule[221]=C:\Windows\system32\EhStorShell.dll
LoadedModule[222]=C:\Windows\system32\ntshrui.dll
LoadedModule[223]=C:\Windows\system32\srvcli.dll
LoadedModule[224]=C:\Windows\system32\cscapi.dll
LoadedModule[225]=C:\Windows\system32\slc.dll
LoadedModule[226]=C:\Windows\System32\StructuredQuery.dll
LoadedModule[227]=C:\Windows\SysWOW64\actxprxy.dll
LoadedModule[228]=C:\Program Files (x86)\Internet Explorer\ieproxy.dll
LoadedModule[229]=C:\Windows\SysWOW64\thumbcache.dll
LoadedModule[230]=C:\Windows\system32\SHDOCVW.dll
LoadedModule[231]=C:\Windows\system32\SearchFolder.dll
LoadedModule[232]=C:\Program Files (x86)\Steam\steamapps\common\FSX\gauges\RCB_Groundhandling5_Sound.dll
LoadedModule[233]=C:\Windows\SysWOW64\uiautomationcore.dll
LoadedModule[234]=C:\Windows\system32\LINKINFO.dll
LoadedModule[235]=C:\Windows\system32\explorerframe.dll
LoadedModule[236]=C:\Windows\system32\DUser.dll
LoadedModule[237]=C:\Windows\system32\DUI70.dll
LoadedModule[238]=C:\Windows\system32\mssprxy.dll
LoadedModule[239]=C:\Windows\system32\NetworkExplorer.dll
LoadedModule[240]=C:\Windows\System32\drprov.dll
LoadedModule[241]=C:\Windows\System32\ntlanman.dll
LoadedModule[242]=C:\Windows\System32\davclnt.dll
LoadedModule[243]=C:\Windows\System32\DAVHLPR.dll
LoadedModule[244]=C:\Windows\system32\wkscli.dll
LoadedModule[245]=C:\Windows\system32\PortableDeviceApi.dll
LoadedModule[246]=C:\Windows\system32\PortableDeviceTypes.dll
LoadedModule[247]=C:\Windows\system32\EhStorAPI.dll
LoadedModule[248]=C:\Windows\system32\twext.dll
FriendlyEventName=Stopped working
ConsentKey=APPCRASH
AppName=Microsoft Flight Simulator®
AppPath=C:\Program Files (x86)\Steam\steamapps\common\FSX\fsx.exe
John
John
« Reply #7 on: March 30, 2019, 04:38:05 PM »
And this:
Version=1
EventType=APPCRASH
EventTime=131983986354985091
ReportType=2
Consent=1
ReportIdentifier=bc541862-52af-11e9-8d20-4061865cd292
IntegratorReportIdentifier=bc541861-52af-11e9-8d20-4061865cd292
WOW64=1
Response.type=4
Sig[3].Value=terrain.dll
Sig[7].Value=00058122
DynamicSig[22].Value=c405
DynamicSig[23].Value=c40584a475c3f8555bbaab9ef93905b4
DynamicSig[24].Value=724b
DynamicSig[25].Value=724b2e36ba5ceb2d52accf848df40bbe
ConsentKey=APPCRASH
John
John
« Reply #8 on: March 30, 2019, 06:00:27 PM »
Just thought of something ::) the flight plan loads fine.  It's when I hit the "Fly Now" button and it loads to about 84% then CTD if that helps ???
John
« Reply #9 on: March 30, 2019, 07:10:51 PM »
At 84%, ... it is loading air, land, and sea traffic.  ;) ???   :-\
I'm wondering about maybe corrupt AI or ai flightplans, etc? ???
« Last Edit: March 30, 2019, 07:32:06 PM by jeff3163 »
« Reply #10 on: March 30, 2019, 07:27:49 PM »
What airport are you trying to load? A specific one or any airport? If it's a specific one, the problem could be something corrupt in the scenery. It's been known to happen with a faulty ADE file.
John
« Reply #11 on: March 30, 2019, 09:46:02 PM »
Jeff, could be, I don't know how to check that stuff though ???
Steve, I've tried KBGR with LR45 and KPHL with MD11.  1st time it happened was out of KPHL and I was in climbout trying new wx engine "FSrealWX 3.0 Close BETA" but I uninstalled that program  :-[
John
« Reply #12 on: March 31, 2019, 12:16:27 AM »
Hi John,
What graphics card do you use and are the drivers up to date?
John
« Reply #13 on: March 31, 2019, 12:57:40 AM »
I have an old GeForce GT240 and the drivers are up to date :(
John
« Reply #14 on: March 31, 2019, 04:14:10 PM »
Ok, now I'm really confused :o I did a trip PAFA-PANC and everything loaded and run great 8) but then tried BGR-BOS and CTD at 86% >:(
John
