Author Topic: Library Order Once and For All!  (Read 1948 times)
LTCSZ
« on: February 11, 2019, 05:35:12 PM »
Where should the Tongass Upper and Lower files be located in the Scenery Library...I have mine listed as 1 and 2 with everything else below them...Is this correct? Running FSX...Thanks!
Beardgoblin
Re: Library Order Once and For All!
« Reply #1 on: February 11, 2019, 06:16:22 PM »
Hi LTCSZ,
check out the load order under the Scenery getting started page http://return.mistymoorings.com/getting_started/index.php
Scroll down to #8 for the Scenery Load Order advice.
And from new guy to another, welcome to RTMM  8)
The New Rig:
AMD Ryzen 5 5600X 4.6GHz, 32 Gig RAM, RTX 2060 D6 6GB V2 GPU, T16000M FCS Hotas, Logitech 3 stick Throttle Quad.
« Reply #2 on: February 11, 2019, 07:33:24 PM »
In other words   Tongass goes between FTX and OpenLC (FTXCentral)  (And RTMM on top).
Do this you are actually creating scenery blocks - then you can move things around as required inside the scenery blocks.
So top down:
3rd party add-ons block
RTMM Scenery: Libs go at bottom, add-ons scenery above.
FTX Block
FTX (ORBX) entries ... ORBX Entries (See FTX Central Discussion below)
Tongass Block
Tongass X Higher Priority ... from the Tongass X Installation   (Higher goes above lower!)
Tongass X Lower Priority ... from the Tongass X Installation
OpenLC Block
ORBX!OPENLC (if you have it) (See FTX Central Discussion below)
Below is the bases stuff, mesh and default sim scenery.
To set up these blocks: set the FTXCentral insertion points.
« Last Edit: February 11, 2019, 07:40:45 PM by nbrich1 »
