Hi
I am using the xml method for RTMM scenery using Lorby's P3DAO. Is this procedure correct?
I'm not sure if I'm handling the Scenery\World\Scenery files correctly.
This is what I do:
1, Create the folders as required for sound, effects, sim objects,etc., and put the appropriate RTMM files in them.
2. I also put files that need to go in Root\Scenery\World\Scenery in a folder structure: scenery\world\scenery.
3. Create, if necessary, the scenery folder, e.g., Tongass Narrows floats, with a 'scenery' sub-folder.
4. Using P3DAO I add 2 entries in scenery: the scenery folder e.g., 'Tongass Narrows floats' and 'scenery\world' [I believe the folder 'scenery' containing files will be read]
5. Then I create 'other add-ons' using Lorby for all the other folders - effects, sim objects, etc.
All folders reside in the same directory.
Thanks.
