Author Topic: Aircraft Add  (Read 140 times)
BBQSteve
Aircraft Add
« on: January 21, 2019, 09:40:54 AM »
Please add the Kodiak Quest, Type Des KODI to the list of flyable aircraft. I wish to use it for MFC0023. Thanks
Re: Aircraft Add
« Reply #1 on: January 21, 2019, 09:59:22 AM »
Quest Kodiak (Aircraft ICAO K100) is already in our fleet:
In Cigar Bar it is coded as "N490MM - K100 - K100"
BBQSteve
Re: Aircraft Add
« Reply #2 on: January 21, 2019, 10:14:14 AM »
It may be in cigar box, but it is not listed in the tours selection, at least not 23.
Allowed Aircraft Types:   AS65, B205, B206, B212, B222, B407, B412, C172, C185, C206, DHC2, DHC3, ICON, J3, M7, PA18
« Last Edit: January 21, 2019, 10:18:05 AM by BBQSteve »
Re: Aircraft Add
« Reply #3 on: January 21, 2019, 10:21:48 AM »
NP, will add that ICAO to the trip before you start. DONE - K100 now there.
(You can always change your plane via the aircraft information box in Cigar Box for any leg).
BBQSteve
Re: Aircraft Add
« Reply #4 on: January 21, 2019, 10:24:01 AM »
WShat does this mean "Please note that you can not change the aircraft type after you have signed up!"?
Re: Aircraft Add
« Reply #5 on: January 21, 2019, 10:47:10 AM »
It means after you choose an aircraft from the tour page on any of the tours, it will propagate that aircraft in Cigar Box for every leg of the tour legs. (can't change that in this "Tour Center" Module.
But in Cigar Box we have the ability to change the aircraft for each tour flight leg after the leg is loaded into Cigar Box.
So you can't change the aircraft after chosen in the specific tour but you can change it on the tour flight leg itself - as per the following pics:
Hope this helps the understanding for everyone.   (I really have get the Cigar Box manual finished- it might help!)
BBQSteve
Re: Aircraft Add
« Reply #6 on: January 21, 2019, 01:15:42 PM »
Certainly does because I thought you must fly the same plane throughout the tour! Thanks for clearing that up.
Walter.Beech
Re: Aircraft Add
« Reply #7 on: January 21, 2019, 04:03:34 PM »
Yes, Norm, thanks for this clarification. This changes things a lot, now I don't have to fly a DC-3 from PF20  ;D
Re: Aircraft Add
« Reply #8 on: January 21, 2019, 04:26:42 PM »
Well Ilya (Walter) nope you don't.. (but if you don't like your selected airplane when you added yourself to a tour or pick the wrong aircraft, just let me know and I can clear you off a tour so you can join again and select the correct aircraft.  (Or just change it when you fly the legs via Cigar Box). Either is not a problem.
