Author Topic: CIRP missing textures  (Read 6995 times)
Lonewolfee1
« on: January 19, 2019, 04:01:45 PM »
Missing this texture at PF48:
And these at PF44:
Re: CIRP missing textures
« Reply #1 on: January 19, 2019, 04:03:41 PM »
Take a picture of your Scenery Checker Abdul Post it for us...
Lonewolfee1
« Reply #2 on: January 19, 2019, 07:00:43 PM »
« Reply #3 on: January 19, 2019, 09:38:54 PM »
Here's what I see at PF48. The object comes from FSXP3D ez-ga hangers ss.bgl, is called ga_hanger_SS_07_open, and the texture used is ga hanger ss 7a.bmp.
This object is in RTMM Required Libraries Part I\EZ Scenery LibraryFSXP3D 6-7-14\EZ Scenery LibraryFSXP3D, which you obviously have or you wouldn't see the textureless hanger.
Look on your system for the above texture. If you don't have it or can't find it, post back.
« Last Edit: January 19, 2019, 09:44:31 PM by ualani »
« Reply #4 on: January 19, 2019, 09:58:30 PM »
Here's what I see at PF44. The First object comes from FSXP3D small airport objects 2.bgl, 818e2c7349a26b0f70d26f872a04f981 Storage Shed, found in the RTMM Required Libraries Part I\EZ Scenery LibraryFSXP3D 6-7-14\EZ Scenery LibraryFSXP3D
The second object is from buildings.bgl, which is included in the FSX or P3D factory installation. The object is gen_housingwood03, and textures used are MD.DDS and MD_LM.DDS
Again, search your system for the above textures. There's really no reason that they aren't on your system since you have the objects.
« Last Edit: January 19, 2019, 10:09:31 PM by ualani »
Lonewolfee1
« Reply #5 on: January 19, 2019, 10:49:29 PM »
Thanks Steve.
ga hanger SS 7a.bmp is listed in a text file called - Old RTMM Texture File Removal List.txt found in
COL Old RTMM Files Removal Utility v1 which is in
RTMM Required Object LibrariesFSXP3D Part I_02.25.2017
ga hanger SS 7a.dds is in EZ Scenery LibraryFSXP3D 6-7-14 as you said
« Last Edit: January 19, 2019, 10:52:08 PM by Lonewolfee1 »
Lonewolfee1
« Reply #6 on: January 19, 2019, 11:02:18 PM »
On PF44
I do have md.dds and md_lm.dds on my system.
« Reply #7 on: January 20, 2019, 08:27:52 AM »
The bmp files were changed to dds when we converted objects and textures a few years ago, so it doesn't matter. I got the bmp name directly from the file texture list the the original objects call for, but it technically doesn't matter.
If you have those textures in their respective texture folders, then there's really no reason that you shouldn't be seeing things as they should be.
Are you using FSX or P3D?
Lonewolfee1
« Reply #8 on: January 20, 2019, 12:28:52 PM »
I am using FSX.
« Reply #9 on: January 20, 2019, 12:40:37 PM »
OK. As an experiment, locate the textures that I listed above and COPY them to your main, FSX texture folder and see if the objects now look correct.
Lonewolfee1
« Reply #10 on: January 20, 2019, 01:18:52 PM »
Thanks.
That solved the problem for PF48.  See it fine now.
I can see one of the textures in PF44 now but not the other.
The one I can see is the first picture you took of the building in the corner at PF44.
The other building by the barrels is still black.
« Reply #11 on: January 20, 2019, 01:20:20 PM »
AND ANOTHER 3 CHEERS FOR STEVE!!!! (Best library manager a site could have!!)
« Last Edit: January 20, 2019, 02:36:42 PM by Doug »
« Reply #12 on: January 20, 2019, 02:05:32 PM »
... and that was just an experiment!  Whoa!   ;D  :P
« Reply #13 on: January 20, 2019, 04:09:29 PM »
Which PF44 texture are you still missing? Post another screen shot, please. BTW, sometimes there can be a lag when loading textures. You can also try to go to your options\scnd rapidly enery menu and exit right back out. If there's a texture loading issue, that will sometimes "fix" it. Another thing to try is to pan or rotate around rapidly in slew mode. For some reason this sometimes makes stubborn textures to reload and then display properly. Weird, huh?
Lonewolfee1
« Reply #14 on: January 20, 2019, 05:49:19 PM »
This is the stubborn one
