Author Topic: MFC0025 leg 11 problem  (Read 3058 times)
doksas
« on: January 10, 2019, 12:42:09 PM »
Hi pilots, i try relog but leg 11 dont activate, any ideas?
Re: MFC0025 leg 11 problem
« Reply #1 on: January 10, 2019, 12:54:25 PM »
MFC0025 Exploring Chitina-Kennecott - actually a leg 10 error.: Leg 10 has appeared to have dropped off the tour.. so you can't get to leg 11 without being able to access or filing 10. Investigating. Might try a manual pirep or Cigar Box charter. (See email on parameters).
I might have to completely rebuild this tour as a new # to be able to redefine the missing leg.  (We had a similar issue back in leg 11 of Tour 16- weird but in MFC0016 a manual pirep was able to be filed and the tour progressed for everyone. Hopefully we can get by this glitch in tour 25 too but if not will quickly rebuild it as MFC0028.. Please keep me posted if you could Igor.. (ps: Happy new year to you-all the best in 2019!.)
« Last Edit: January 11, 2019, 05:53:54 AM by nbrich1 »
doksas
« Reply #2 on: January 10, 2019, 01:01:13 PM »
I try twice but not accept
"The flight code and number you entered is not a valid route!"
doksas
« Reply #3 on: January 10, 2019, 04:01:01 PM »
Just finish charter flight but still same probem
11   LAST   Last Resort   CXC   Chitina   00:57:00   N/A
« Reply #4 on: January 10, 2019, 06:14:42 PM »
Yup.. Will have to rebuild - can't recover the missing leg.. but it shouldn't take me took long..
MFC0025 >> will become new tour MFC0028. Arg. Stand-by Igor & Danny.
Note: Leg 9 and 10 have changed - Will now reflect Burwash (CYDB) instead of Klutian Glacier. (KLUT)
Will have you both caught up for the new leg 10 starting at Burwash (CYDB) on the rebuilt tour momentarily!!
Igor - done.
Danny -  done
Thanks guys for your help and again apologize for the inconvenience.
« Last Edit: January 11, 2019, 05:57:42 AM by nbrich1 »
doksas
« Reply #5 on: January 10, 2019, 07:19:01 PM »
Thanks Norm, but now i bid fight and everything is ok but when go on flight now no bids.
Just now i flight leg 10 charter flight and when finish i try to file pirep...
doksas
« Reply #6 on: January 10, 2019, 07:47:39 PM »
Now is ok, i am on leg 11 bid works. Thanks Norm you are great man !
« Reply #7 on: January 10, 2019, 09:57:52 PM »
Indeed all is good again. The tour rebuild all ok and is working as intended. Have fun flying the rest of the trip and will see you in the RTMM skies, hmmm but perhaps not since you are 5 legs ahead of me! lol.
« Last Edit: January 11, 2019, 06:01:40 AM by nbrich1 »
doksas
« Reply #8 on: January 11, 2019, 08:37:04 AM »
I'll be waiting you in PANC Norm  ;D
RCFlyer
« Reply #9 on: January 11, 2019, 04:40:39 PM »
Norm:
When I try to add a bid to fly the next leg it says the bid has been added, but, when I go to my bids it indicates I have no bids active.
Danny
doksas
« Reply #10 on: January 11, 2019, 08:30:18 PM »
RCFlyer, same problem with me, but this leg flight as charter in cigarbox and file pirep when finish flight ..from next leg everything is fine
« Reply #11 on: January 12, 2019, 08:14:53 AM »
Ok working. Now just made another tweak.. Leg 9/end or 10/start seems to have some ICAO system error or address issue: which is generating the bid but not allowing its viewability.
Since you have progressed by those legs now, you won't have any more problems.
And now will make another change to the destination or final ICAO for leg 9/end, leg 10 start and hopefully this ICAO change will allow the bids to flow through with being interrupted.
Thanks for your help on this. I know the MFC system very well but it's these little system errors that randomly pop up and cause some grief.
RCFlyer
« Reply #12 on: January 12, 2019, 09:58:18 AM »
Great work Norm.  One suggestion.  In leg 11 you used one of your custom airport/waypoint titles, LAST.  Because this title is a custom one nooneelse has this title in their sim database.  At least I didn't.  Therefore, when I try to find this location in my sim it isn't there.  For LAST the actual title in the sim is RT01.  I believe this title came with the scenery from RTMM.  Anyway, if you could use the titles that come with the RTMM scenery it would make finding the locations easier.
Danny
« Reply #13 on: January 12, 2019, 10:43:27 AM »
Right on Danny and understand. Not all names/location are present in RTMM scenery (some were just glacier surfaces), but will work on it.
Thanks again for your help.
