Author Topic: Moving up the ranks  (Read 1767 times)
scanham
Moving up the ranks
« on: December 20, 2018, 09:16:54 AM »
I see from the Pilot Center that I need 16.86 hours for promotion which would give me a total of 25 hours.  Does that continue on the same scale (25 hours per level)?
Also, at the Misty Flying Club page, under the "Pilots" tab, I see only 7 pilots listed.  Why is that and is there a place to see the entire roster of pilots?
Thanks for everything.  This is really fun!
Steve Canham
MFC0077
Re: Moving up the ranks
« Reply #1 on: December 20, 2018, 12:17:57 PM »
Ok Steve:
Pilots Tab: Sorry bout that: the full list of pilots is now visible again under that Pilots tab.
Ranks/Levels:
Will talk to Henry about the possibility of putting the levels listing on a tab under Pilot Center as well as the other award listings (Years Service, Flight Hours, # of flights, All of the tour awards etc. so that these listings might be viewable by all pilots). Will work on it.
To your question about the levels: below is the criteria for the Pilot Levels/Ranks Badges:
Level                            Minimum Hours:
Misty Bush Pilot Level 1   0
Misty Bush Pilot Level 2   25
Misty Bush Pilot Level 3   50
Misty Bush Pilot Level 4   100
Misty Bush Pilot Level 5   200
Misty Bush Pilot Level 6   300
Misty Bush Pilot Level 7   400
Misty Bush Pilot Level 8   500
Misty Bush Pilot Level 9   600 and over
(Will add/design more later as required)
Glad you're enjoying flying up here in the "RTMM frontier" and will ensure that you have plenty to fly for a long, long time!!!
« Last Edit: December 20, 2018, 12:44:22 PM by nbrich1 »
scanham
« Reply #2 on: December 20, 2018, 04:59:55 PM »
Thanks Norm!
One other question.  The seven of us, who were displayed prior to your change, are grouped together at the end of the list, under the heading: "No Hub".  Do we have to earn the hub membership?
Steve Canham
MFC0077
« Reply #3 on: December 20, 2018, 05:19:06 PM »
Thanks Norm!
We only have one hub which is PF20-Misty's Place and all pilot's are members of the hub (No earning required). (I did a manual pilot's refresh for you guys and now the Pilot's list shows complete and all show as part of the main hub). Thanks Steve.
« Last Edit: December 20, 2018, 05:23:45 PM by nbrich1 »
