Author Topic: Cigar Box  (Read 410 times)
simondix
Cigar Box
« on: October 26, 2018, 04:31:19 PM »
Unable to log in to Cigar Box.  States  'Unable to read Data from Transport Connection.  Connection Closed'
Re: Cigar Box
« Reply #1 on: October 26, 2018, 05:10:53 PM »
Shutdown your PC and your router/modem. Then start them up again and give it a try. (Make sure your FSUIPC is installed for your sim and run cigar box as administrator).  The Cigar Box/MFC connections are currently all up and running without a hitch-right now. (8 pilots are currently online in Cigar Box- including one from Belgium).
« Last Edit: October 26, 2018, 05:52:51 PM by nbrich1 »
simondix
Re: Cigar Box
« Reply #2 on: October 27, 2018, 11:12:18 AM »
Thanks I will give it a try later and let you know
simondix
Re: Cigar Box
« Reply #3 on: October 27, 2018, 06:17:22 PM »
No joy.  Switched off the modem and ran as administrator.  Uninstalled and re-installed again and still no joy.  Still the same message coming up.
simondix
Re: Cigar Box
« Reply #4 on: October 28, 2018, 04:34:09 AM »
AVG
Re: Cigar Box
« Reply #5 on: October 28, 2018, 06:50:50 AM »
That sure would explain it Simon. Virus scanners/firewall can sure block you and give this result. No expert here but I have been reading on your problem and the string response you mentioned: "Unable to read Data from Transport Connection. Connection Closed". It yields lots of results: "Firewalls can be set to "forcibly" close a socket if it does not meet the criteria of the firewall rule.. "
https://www.codeproject.com/Answers/686460/unable-to-read-data-from-the-transport-connection#answer1
Soon as saw your "AVG"  it makes sense. That virus scanner had apparently created a firewall rule against the cigar box connection whatever reason and closed the connection. Arg.
Did you adjust AVG to allow cigar box connection through its firewall? or what did you do to fix or is Cigar Box connection working again?
« Last Edit: October 28, 2018, 07:00:36 AM by nbrich1 »
simondix
Re: Cigar Box
« Reply #6 on: October 28, 2018, 07:30:45 AM »
Yes and is working so about to test it out thanks.
