Author Topic: Ketchikan Ferry / UKVFR Library  (Read 6072 times)
Garry
« on: September 06, 2018, 04:09:51 PM »
Good day fellow RTMMers
2 queries:
Is UKVFR lib required?
Does anyone else have trouble with the Ketchikan ferry? I've had the s/w for about 2 years, used it many times and I've only seen the ferry twice. (Those poor passengers waiting on the road!)
Re: Ketchikan Ferry / UKVFR Library
« Reply #1 on: September 06, 2018, 05:06:50 PM »
In a nutshell, if you have all of the RTMM libraries installed then you have everything you need UKVFR-wise as far as our scenery needs are concerned.
« Reply #2 on: September 08, 2018, 07:49:04 AM »
I will go one step further and say that a separate UKVFR library could interfere with our libraries since we upgraded the UKVFR objects that are contained in our libraries to work with the latest versions of P3D.  The old UKVFR library objects will not display in the latest versions of P3D.
Garry
« Reply #3 on: September 12, 2018, 12:25:24 PM »
Duly noted. Thanks to you both for responding.
Garry
« Reply #4 on: September 14, 2018, 03:32:50 PM »
Good news everyone! I deleted UKVFR and the PAKT ferry is there!! Can't thank you both enough. I'm a happy camper.
Garry
« Reply #5 on: September 14, 2018, 04:16:06 PM »
Premature excitement. I just activated PAKT v115 and that seems to remove the ferry. Is this possible?
Garry
« Reply #6 on: September 21, 2018, 07:52:14 PM »
Well it seems that activating PAKT v115 deactivates the Ketchikan Ferry. Everything else is there - passengers, vehicles etc..
Any ideas on how to solve this anyone?
Thanks.
« Reply #7 on: September 21, 2018, 08:11:12 PM »
     FYI, the cars and walk-on passengers are not "part" of the ferry.  I made them as addons for the ferry, but they are separate items.  Eye candy.  ;)
Garry
« Reply #8 on: March 23, 2019, 09:29:27 AM »
just a quickie - in the project 144 folders is a file 'trafficBaltiysk.bgl'
I assume this is not to be used for ketchikan and I can delete this?
thanks.
jeff - long time no reply! apologies. and jolly good eye candy it is too!
« Reply #9 on: March 23, 2019, 10:02:19 AM »
Hmmm, this file is not part of "PAKT Ferry.zip" which is in the RTMM scenery download.
I assume you downloaded the ferry file somewhere else (maybe AVSIM.RU ?) The download  there has your mentioned file in the package
« Last Edit: March 23, 2019, 10:11:47 AM by Dieter »
Garry
« Reply #10 on: March 24, 2019, 08:56:31 AM »
Yes I think I did. That would explain it.
Thanks.
