Author Topic: RTMM Flight Plans  (Read 1783 times)
jmsmth
RTMM Flight Plans
« on: July 18, 2018, 01:36:07 PM »
I am about to start flying some of the RTMM flight plans.  I understand how to get the flight plan but how do you set it up in cigar box?  Do you have to enter them as a charter flight?
Jim Smith
Re: RTMM Flight Plans
« Reply #1 on: July 18, 2018, 03:56:33 PM »
You can do via direct flight number entry.. or bt bid. To generate the bid go to your pilot center and view schedules.. click select all.. from there you will get a list of all the flights and on each an option to add each as bids..
Then in cigar box just get flight data and it will load your first bid.. when done that flight, it will generate your next bidded flight and so forth..
If you use the direct flight number entry just remember to go to settings in cigar box and click the search flight number box.. and if you back to bid, to uncheck that box.
So very easy to fix these singles as either bid or flight number..
jmsmth
« Reply #2 on: July 18, 2018, 05:35:09 PM »
Thanks.  I tried both methods and both work fine.
Jim
